different versions
First post, by futurama rox
hi!
Is there a way to figure out what changed between the different glidos versions?
i see there is already a v1.28 ... is is worth installing ?!? what changed ?!?
some kind of Changes.txt ?
thanks for the answer...
Reply 1 of 3, by Glidos
Yeah, I should do that. I have the whole thing under CVS, but there isn't a single file at the moment which lists the changes.
What version are you using at present?
Reply 2 of 3, by Qbix
Rank DOSBox Author
DOSBox Author
you can use some nice scripts to parse it for you.
take a look at
http://pcnwstage.phys.rug.nl/dosboxcvs.txt
this lists all changes since 0.61 (for dosbox that is)
I'm sure you can create something like that as well that is version based.
Water flows down the stream
Reply 3 of 3, by futurama rox
i'm using v1.27 (or maybe it's v1.26? i'm not home right now so i can't tell exactly...)
but IMHO it would be generel a good idea a changes file, so people could check what's going on 😀
