My 486 (150MHz and Voodoo! :)
First post, by sledge
Last few months I've been building 486 class computer for my retrogaming needs and this is the outcome:
  • Am5x86@150MHz (aka 486DX5)
    Abit PB4 mobo (ALi M1487/M1489 chipset)
    64MB RAM
    4GB CompactFlash HDD
    STB Lightspeed 128 (Tseng ET6000)
    Sound Blaster AWE32
    + 3dfx Voodoo 1
    (and 8x Mitsumi CD-ROM, 5.25 + 3.5 floppy)
Right now I am trying to find games which would benefit from Voodoo card. So far I tested Quake (barely playable, with average 12 FPS), Carmageddon (unplayable) and Descent with 3dfx patch (perfect - 25 FPS in 800x600!)
Quake timedemo: http://www.youtube.com/watch?v=suC5MRdJ8as
Speedsys results:
In the future I would really like to get Cyrix 5x86/133MHz CPU and maybe SCSI harddrive. Any other suggestions? 😀
doshaven.eu / high-voltage.cz
Reply 1 of 38, by dirkmirk
Good to see someone else try a 3D card on a 486 system!
In my experience the best CPU to use is the Pentium overdrive 83mhz, I use a Voodoo3 on my machine but I dont think it would be any faster for this class of machine compared to the voodoo1.
For reference at 640x480 in Quake timedemo I got 27.0fps and 26.9fps at 800x600, cant remember the exact figures for the Cyrix 5x86-120 but its noticeably slower.
Did you run the quakedemo with the -nosound option?
Reply 2 of 38, by sledge
Yep: glQuake -width 640 -heigh 480 -nosound -nocdaudio -nonet -nojoy +timedemo demo2
With Voodoo 2 card there was no difference, bottleneck there is obviously the CPU 🙁 Pentium Overdrive is an option, but I would like to stick with "true" 486 CPU. I know Cyrix 5x86 has few Pentium instructions, but...its stil 486 class CPU 😀 And according benchmarks, it IS considerably faster than Intel/AMD CPUs in some ways.
Reply 3 of 38, by vetz
Good luck getting a Cyrix 5x86/133MHz. They are rare and expensive.
Other early Voodoo games that might run well on a 486:
Battle Arena Toshinden
Descent II
Scorched Planet
Whiplash/Fatal Racing
Extreme Assault
Starfighter
VR Soccer/Actua Soccer
Tomb Raider
Reply 4 of 38, by sledge
Yeah I know. But maybe one day luck will smile on me! 😀
Thanks for game suggestions. I tried Tomb Raider and to my surprise, it works great! After that "Quake fiasco" I wasn't expecting much, but it is really smooth and playable 😀
Reply 5 of 38, by Anonymous Coward
You can always have a shot at running an IBM 5x86C at 2x66. Though, you'll have to do some soldering to get the magic 3.85V.
Reply 6 of 38, by feipoa
dirkmirk wrote:
Good to see someone else try a 3D card on a 486 system! […]
Which motherboard were you using? Using W95, I noted 27.5 fps at 640x480 with an Am5x86-133 at 160 MHz. I also noticed that the Voodoo3 performed a fair amount better than the Banshee in GLQuake (26.0 fps vs. 24.0 fps, for example, in NT4).
Reply 7 of 38, by RacoonRider
We want some pictures! Also, make sure you submit your results to Phil's ultimate VGA benchmark. You would have to revert to stock clock to make it to the main table though...
btw, Speedsys mentions S3 videocard, not ET6000 😕
Reply 8 of 38, by feipoa
vetz wrote:
Other early Voodoo games that might run well on a 486: Battle Arena Toshinden Descent II Scorched Planet Whiplash/Fatal Racing E […]
Descent II
Scorched Planet
Extreme Assault
Starfighter
Tomb Raider
Do any of these have a timedemo or some sort of benchmark?
Reply 9 of 38, by vetz
Descent II
Scorched Planet
Extreme Assault
Starfighter
Tomb Raider
No timedemos or benchmarks.
Battle Arena Toshinden have a frame-counter built in. You reach the FPS limit of 30 FPS on a Pentium 90 (even on a Pentium 75 should max it out). I also believe the 3DFX version of Tomb Raider have a framecounter, but I may recall incorrectly and mix it with one of the other 3D accelerated versions.
Reply 10 of 38, by feipoa
Are there any DOS/Win95 games from approx. 1995 to 1997 which have a timedemo and take advantage of GPU acceleration (preferably 3dfx, OpenGL, or D3D) and were targeting the P75-P166 crowd besides Quake, GLQuake, and Quake II?
After achieving close to 30 fps in GLQuake on an Am5x86, I am curious which other titles, that were once considered only playable on a Pentium, can also be made playable on a 486 with a suitable graphics card.
Reply 11 of 38, by leileilol
Try Battlezone and Interstate '76 Gold.
Reply 12 of 38, by feipoa
Ok, so Tomb Raider has a frame counter and BattleZone (1998) and Interstate '76 Gold have timedemos? How do I run the timedemos? Are these D3D or 3Dfx games?
Reply 13 of 38, by sledge
Wow! How the hell did you squeeze 30fps from the humble Am5x86? 😀
Reply 14 of 38, by leileilol
GLQuake defaults to gl_flashblend 1 which means much less lightmap updates (none for dynamic lights), which could further be reduced by r_dynamic 0. GLQuake is far more playable on a 486 than the software renderer 😀
Reply 16 of 38, by feipoa
Mau1wurf1977 wrote:
GLQuake processor and resolution scaling with Voodoo2 attached 🤣
Interesting, so a P100 would get about 45 fps. Did you notice the screen resolution of the game play change when you set the resolution to 800x600? For some reason, 640x480 and 800x600 look identical to me, with the exception of the console font. Why is this?
Reply 17 of 38, by dirkmirk
PC CHIPS M918i with 512k cache, I have misplaced the original bios chip.... I tried using a newer flashed bios to get support for the cyrix 5x86 but it isn't the same as the Amptron DX9300 which is stated on the Mbarren.net website.
edit: I think it was the SIS chipset, I had better results with the ALI chipset according to my post about the board I got 40.1fps in the quake timedemo test using a POD83, however it still had significant slowdowns during the open areas or lots of enemies so its a bit misleading really.
Quick test ALI 1487/89 with Voodoo 3 & Riva TNT (PCI 486)
Reply 19 of 38, by leileilol
Voodoo2 > Voodoo1 for 486. Don't underestimate multitexturing, means less passes of polygons through the slow bus.
It's also possible to "run" Quake III Arena on a 486 with a Voodoo2 also 😀 should roughly be 4-7fps, most of the CPU being sucked on the sound and shader code (realtime texturemapping calculations) due to a ton of float operation
