First post, by GeorgeMan
- Oldbie
Hello forum!
In a Win 98SE installation that everything works good, I've installed a NEC-based PCI USB 2.0 card.
It gets detected, I've installed 3-4 different drivers that all get it to work, my USB 2.0 stick is installed and I can see all my files inside it.
I installed many programs from there, eg daemon tools, windows media player etc. No problem whatsoever.
BUT, when trying to copy larger files, even playing mp3 files from the USB, or mounting an ISO, all ends up with errors. Blue screens, ISOs not working, mp3 playing stops.
The system is a bit overcrowded, having a PCI 3com ethernet, SB Live! SB0060 with SB16 emulation, 3dfx voodoo2 and a GF 6800. But I've disabled LPT and COM ports and it seems that I've not run out or recourses as nothing gets an exclamation mark in control panel.
So, what can I do to fix this? 😕 😕 😕
Acer Helios Neo 16 | i7-13700HX | 64G DDR5 | RTX 4070M | 32" AOC 75Hz 2K IPS + 17" DEC CRT 1024x768 @ 85Hz
Win11 + Virtualization => Emudeck @consoles | pcem @DOS~Win95 | Virtualbox @Win98SE & softGPU | VMware @2K&XP | ΕΧΟDΟS
