Retro Rig Photo Thread
Reply 660 of 3346, by Sutekh94
I remember that video. The Leo's a neat little system, basically the same thing as this Unisys branded system. I'd like to have one of those some day.
My YouTube | My DeviantArt
Reply 661 of 3346, by Splinter
Almost finished the Celeron 366 on Zida 60 Create LX-CT socket 370 mobo, new and unused.
Voodoo 3 3000 AGP (Mexico)
384 mb ram
40gb hdd
Brand new Noga psu AT 300w (from 2004)
Via lan and 4 port USB 2.0
Win 98SE
Strapped a case fan to the V3 using cable ties. It's not pretty, but it's adjustable and it works 😀
http://www.compufixshop.com
Main rig Ryzen 2600X Strix RX580 32GB RAM
Secondary rig FX8350 GTX960 16GB RAM
Reply 662 of 3346, by pewpewpew
That's amusing -- I have the evil twin of that case.file.php?id=15647
Reply 663 of 3346, by luckybob
The floppy drive cover is upside down!!! ARRG! What is wrong with you people?
Reply 664 of 3346, by pewpewpew
..and I was /this close/ to re-shooting my box with the cover flipped to match, but decided merely slippin down was enough.
Reply 665 of 3346, by Splinter
OMG....grabs coat and exits.
Reply 666 of 3346, by AlphaWing
Yea that floppy cover....... needs painted.
Reply 667 of 3346, by Splinter
This came out of the case earlier:
Reply 668 of 3346, by AlphaWing
Oh wow if that 486 board still works... I woulda kept that in!
Especially in a such a retro looking case like that.
I'm just hoping to come across such a machine again at a thrift store\fair\show\fest.
Don't trust the mail\ups\fedex with such a machine. I'm sure it would arrive broken and dented to heck, like the last large item I ordered.
Reply 669 of 3346, by Solarstorm
Just for completness here are some Pics of my 2003ish PC i just dragged out of the closet.
http://imgur.com/a/6gaY8
My YouTube Channel
Reply 670 of 3346, by obobskivich
That's had some post-2003 upgrades... 🤣 What CPU is in there? Very nice looking machine btw. 😀
And a pictorial contribution:
This is my new (to me) Intel D875PBZ and 3.2EE on the bench for testing (everything seems to work AOK 😀):
Reply 671 of 3346, by RacoonRider
The link has the word "gay" in it and Usergate does not let me view this from work 🙁 I wonder what's so bad about the gay people that it got banned by admin.
Reply 672 of 3346, by Solarstorm
Damn gays! Dey tewk arr jerbs!!! 😁
My YouTube Channel
Reply 673 of 3346, by AlphaWing
This is my latest retro rig.
When I received this machine I was expecting a 386 or 486, but this is what I got.
Someone had upgraded it in the past.
Frankly it dashed my dreams of a working 486 but whatever 🤣.
This is good too, and the TURBO switch works I can switch bewteen 133\233mhz.
When I got the machine the insides were coated in this sticky oil substance, I think the PC saw use in an industrial setting.
It only came with Onboard video a broken 1gb WD HD, and both floppies I had to take apart, and thoroughly clean due to this oil coating. It also came with a generic AT Power supply dated 1990 THAT, is not seeing use 🤣, the caps have rust spots all over the visible metal tops, I used a AT-ATX power supply converter cable despite the fact this board has an ATX power plug, to preserve the wonderful mechanical power button too. The pictures don't do justice for the case... the sucker is built like a tank, it weighs a close to a good 30 pounds.
It has been upgraded to whats listed below since I got it.
Specs
Motherboard - Asus Sp97v - BABY AT socket 7 motherboard, Sis 5598 chipset
CPU - Pentium 233mmx
Ram - 4x32mb 60ns Edo for 128mb total.
Primary Video - Creative Labs - 3d Blaster Riva Tnt PCI 16mb - NV4
Secondary Video - STB - Black Magic Voodoo 2 12mb PCI
Sata Controller - Promise Sata 150 tx4 PCI - (no raid support on this one)
Sound card 1 - Creative Labs Sound Blaster Pro ISA - CT1600
Sound card 2 -Creative Labs Sound blaster AWE32 ISA fully upgraded with x2 16mb simms - CT3670
Storage - x2 320gb WD 7200rpm 2.5in laptop Sata I HD's plugged into the promise controller.
Storage - 8gb Transcend CF card into the Mobo IDE controller (used for boot, and OS)
Optical - 16x Sony Dvd Drive.
Floppy - 3.5 and 5.25, 1.44m\1.2mb : Mitsumi and Panasonic
Power Supply - Enermax 300watt PSU : EG351P-VE
OS - Win98se is installed currently.
Pictures:
Came with this P166 in the picture, and USB bracket there is also a video bracket for the onboard sis video.
So far other then an issue with the sound not passing into the SB-PRO from the Awe, when booting into dos before loading windows, this machine is a great stable thing, and is more then likely going to be my main socket 7 rig for a long while.
Reply 674 of 3346, by Callahan
is this ps/2 to usb adapter working?
Cpq: ap550(2x1G/256k), sp750(2x900/2MB), 5100(2xpII300)
TD-30 2xP166 NT 3.51
HP Vectra XU 6/200 2x PIIOD 512MB FPM Banshee
Super S2DG2@550/2MB SCSI 15k V5 5500
P4T533-C P4 3,06 Ti4600
Dell T700r @P3-700 V3 3500
PR440FX-2x PIIOD Voodoo 4500 PCI r320 CT1920
Reply 675 of 3346, by GeorgeMan
For mice that support operation in ps/2 mode, of course it is! I'm using a similar one myself.
HP Elitebook 14 G1a | Snapdragon 12core | 32GB LPDDR5X RAM | Adreno GPU | 32" AOC 75Hz 2K IPS + 17" DEC CRT 1024x768 @ 85Hz
Windows 11 on ARM --> pcem ARM | Eden & Dolphin ARM editions
Reply 676 of 3346, by AlphaWing
Yes they work fine with most USB mice\trackballs.
Most come with them when you buy them new.
Reply 677 of 3346, by RacoonRider
A double-FAN PSU! It's probably the first time I see one. I remember some newb on some other forum saying "Always pick double-FAN PSU, single-FAN models are always cheap and worse than double-FAN".
Well, Corsair RM750 I purchased recently can be called anything but cheap 😁 I got it for my Q6700/HD4870X2 powerhouse with prospects to power a newer PC in case I need one in the future.
Reply 678 of 3346, by oerk
Really? I've had an Enermax PSU with two fans more than ten years ago. Original intention behind them was to transport hot air from the CPU / video card out of ATX cases, back when fans in the back of the case were not the norm. It doesn't make much sense in an AT case, of course.
Modern PSUs with their huge 140mm fans at the bottom don't need fans at the back anymore.
Reply 679 of 3346, by RacoonRider
Exactly. They were really useful powering tiny ATX cases where PSU is mounted over the CPU to save space, very typical for Socket 370. In these cases there's no extra space to fit even a 80mm FAN.
