Reply 4901 of 59134, by Holering
badmojo wrote:
Picked up some IDE->CF adapters to try out - they're so freaking cheap that I figured I might as well.
TBH I think that's pretty good for a CF adapter. It's not like your running Windows 7 or 8 with constant writes on a multi-core cpu. Your probably doing permanent installations and mostly reads afterward right? I wonder if it even bottlenecks 486's (probably not).
Reply 4902 of 59134, by Artex
Such a simple thing and so useful.
Reply 4903 of 59134, by sliderider
Splinter wrote:
Slide I never would have noticed to be honest, but thanks for pointing it out. Collected the card this morning and the bloke was […]
Slide
Collected the card this morning and the bloke was very unhappy to sell it as he'd had it for about 15 years and is in pristine condition.
Perhaps down here in Argentina, they came with the Voodoo 1 pack, who knows?
Which missing CD's are you referring to?
Presumably the picture below is how the V2 was presented:
I would have to find which box I stored mine in to be sure, but of course the first thing that would be missing would be the driver CD for the Voodoo 1 card plus I think there may be another game missing. I'm pretty sure there was supposed to be 6 CD's in that pack.
Wait. You know what I think it is?
Mechwarrior 2 for 3dfx.
Reply 4904 of 59134, by RacoonRider
Got 3 exact same adapters. Very useful cute little things! As opposed to IDE2SD adapters, these work in almost any system supporting IDE. As a matter of fact, I think the main bottleneck in 486 stogare system is the controller/bus, not the card/adapter.
Reply 4905 of 59134, by gerwin
I use two IDE2SD adapter on a similar bracket (KTC FC1306 T chip). On 486, socket 7 and Slot-1 systems. The previous 486 BIOS had little trouble detecting the 2GB card, but other then that I never had any issues. The advantage of SD was that fine ones were being discarded everywhere, and that I can plug them in any of my modern systems without adapter.
The Transcend Disk on modules (DOM) seem a little faster, but they are a little more temperamental to configure, also they don't give a means of easily transferring files to another system. One can always combine a DOM as primary and a IDE2SD as secondary.
Not saying there is anything wrong with Compactflash, and full fledged SSD's for that matter.
Reply 4907 of 59134, by Splinter
My current collection of 3dfx cards.
Powercolor Evilking V4 4500
Voodoo 3 3000
The two in the middle are Techworks Power 3D V2's
Bottom Diamond Monster 3DII V2
http://www.compufixshop.com
Main rig Ryzen 2600X Strix RX580 32GB RAM
Secondary rig FX8350 GTX960 16GB RAM
Reply 4908 of 59134, by GeorgeMan
What about Voodoo1? xD
Acer Helios Neo 16 | i7-13700HX | 64G DDR5 | RTX 4070M | 32" AOC 75Hz 2K IPS + 17" DEC CRT 1024x768 @ 85Hz
Win11 + Virtualization => Emudeck @consoles | pcem @DOS~Win95 | Virtualbox @Win98SE & softGPU | VMware @2K&XP | ΕΧΟDΟS
Reply 4909 of 59134, by schlang
I stick with (fast) IDE drives. I need to hear the HDD working otherwise the silence is killing me 😁
Reply 4910 of 59134, by Splinter
Funny you should say that, I've just located two at around $15 each 😀
Reply 4911 of 59134, by GeorgeMan
Target locked, fire! 🤣
Reply 4912 of 59134, by Lukeno94
I know that feeling, I'm going to miss hard drives and their noise when SSDs finally take over.
Reply 4915 of 59134, by retrofanatic
I wish I knew, but from looking at the PDF manual for each, they both seem to have the exact same connectors including 2 MIDI IN and 2 MIDI OUT ports, but who knows if the circuitry is the same.
I don't blame you for asking though...I wouldn't be experimenting with those beauties either...their certainly not easy to find, especially at a good price.
Reply 4916 of 59134, by PeterLI
Reply 4917 of 59134, by fyy
Sometimes that's the only way to know the computer is doing something! There's a black screen, but you hear the hard drive doing its whiz and clicks, and you're like "Ahhh, it didn't freeze, it's just busy!"
Reply 4918 of 59134, by nforce4max
Decided to take a chance and bought a K5 PR133 off amazon that isn't in the best shape. Payed a steep $14.49 for it D:
If it is alive going to do some overclocking tests with it including undervolting.
Reply 4919 of 59134, by JidaiGeki
Picked up this lot for AUD10 ...
All untested, but includes 6 Voodoo 1 cards, 3 Voodoo 2, Matrox m3d, couple of SB 2.0s, an SB16, PAS, Video Blaster RT300, etc. Also a bunch of VESA cards, which I have never owned before. Looking forward to some long weeks of testing 😁
