Slot 1 Intel 440Bx Build
Reply 40 of 44, by Nahkri
Tetrium wrote:
Are you still using that same PSU? I had one from the same brand and it was really cheaply built
No,i,m using another psu,the 1 in the picture had swollen caps,i recovered the good caps and the fan from it and binned the rest.
Reply 41 of 44, by obobskivich
Holering wrote:
That's a nice looking Soyo mobo you got there.
Agreed. Neat system overall. I always saw those translucent teal "Apple wannabe" cases back then, but never actually bought one myself - now they're kind of becoming a curiosity in their own right (don't see them very often anymore).
Curiosity: does that Pentium 2 actually need the cooling fan if you aren't overclocking it?
Reply 42 of 44, by Nahkri
I bought the case as a used product,not so much becouse of the looks,but becouse it's spacious and has the psu mounted horizontaly,back in 2000-2001 i had an atx case which had the psu mounted vertically parallel with the motherboard,covering the cpu area and making acces to the cpu hard,plus u had to be carefull about how tall the cpu cooler and fan was,so it would fit.
Haven't tried running it without the fan,i need to install some monitoring program to work on windows 98se,so i can monitor temperatures from windows.
Will an older version of motherboard monitor work?
Reply 43 of 44, by GeorgeMan
The cpus of that era don't have an integrated thermal sensor, so whatever reading you get is from a motherboard sensor, which is faaaar away from cpu.
Totally unreliable in other words. I would strongly recommend against running it fanless unless you have these big passive slot1 coolers aaand a case fan right behind it, extracting the heat out of the case.
Acer Helios Neo 16 | i7-13700HX | 64G DDR5 | RTX 4070M | 32" AOC 75Hz 2K IPS + 17" DEC CRT 1024x768 @ 85Hz
Win11 + Virtualization => Emudeck @consoles | pcem @DOS~Win95 | Virtualbox @Win98SE & softGPU | VMware @2K&XP | ΕΧΟDΟS
Reply 44 of 44, by cdoublejj
I HAD ONE !!! For a little while then sold it. I wanted to build hackintosh with it and get the matching apple teal green keyboard, and then some how find a matching monitor, i even found matching power strip/surge protector. 🤣
