Mod3 key not working
First post, by marooned_on_mars
So, as I'm using DosBox on Debian, and I need some key combinations that involve ctrl, alt and a function key (which typically switches the display to a TTY) I thought of adding the super key (windows key) as the third modifier key, so I could use it for actions (such as taking screenshots or recording sound/video) that used to have the ctrl and alt combinations. The problem is that whenever I quit DOSBox and start it again, Mod3 key doesn't work anymore (while the other modifier keys work fine), unless I bring up the keymapper, delete the key set to Mod3, add it again and save. I'm currently on r3869 but it also happens on 0.74 (IIRC).
Also, is there any way to make alt+tab work while the mouse is captured? It's quite annoying having to uncapture the mouse every time I want to switch to another window.
Reply 1 of 9, by marooned_on_mars
I guess nobody around here knows what to suggest, so I guess I'll file a bug report, maybe this might get more attention there.
Reply 2 of 9, by Qbix
Rank DOSBox Author
DOSBox Author
So if I understand it correctly, your report is that the mod3 key isn't saved/loaded from the mapper file ?
Water flows down the stream
Reply 3 of 9, by marooned_on_mars
I'm not sure if that's the exact thing that's happening, but it would seem like so. The stdout does not specify anything of a problem when loading the mapper file.
The thing is whenever I start DOSBox, Mod3 is set to a custom key (ie. the super key is mapped as "unknown key" for some reason, maybe that's what's causing the problem?)
Reply 4 of 9, by Qbix
Rank DOSBox Author
DOSBox Author
can you attach the mapperfile ?
Reply 5 of 9, by marooned_on_mars
Sure, here you go.
Reply 6 of 9, by Qbix
Rank DOSBox Author
DOSBox Author
indeed it is mapped to an unknown key (all unknown are mapped to 0)
mod_3 "key 0"
It shouldn't be too hard to add the winkey to mapping table. Is usescancodes on or off at your place ?
Reply 7 of 9, by marooned_on_mars
Yup it is. 😀
Reply 8 of 9, by Qbix
Rank DOSBox Author
DOSBox Author
I'll pm you a little patch tomorrow to determine the key number that we need.
you might want to try if it is different with usescancodes turned off, (as the mapper file will be different in that case)
Reply 9 of 9, by marooned_on_mars
Will be waiting for it, thanks a bunch!
