First post, by Guest
Hi
I've been trying to get VDMS 2.1.0 to install, but haven't gotten around to getting it to work. I've previously used VDMS 2.0.4, and it worked properly. But now I tried to install 2.1.0 and in the process uninstalled 2.0.4, and neither of them work. The VDMS support board @ SF offered manual implementation of a .reg file, but I suppose that was a 2.0.4 feature, since a .reg file didn't appear with the 2.1.0 installation.
I consulted the FAQ for help, and it suggested that a virus shield or programs like SiSoftware Sandra could interfere with the installation, so I uninstalled Sandra and disabled my virus shield, but got the same response.
After my first installation of 2.1.0 the 'Run with VDMS' option from the right-click menu was gone, and manually running DOSdrv.exe just came up with a "class not registered" error box for a number of VDMS dll's.
They appeared as following:
Unable to instantiate emulation module 'VDMServicesProvider'.
0x80040154 - Class not registered (D:\PROGRA~1\VDMSound\VDMS.INI:66)
Do you want to continue? (Yes/No)
Continuing with the program just brought up a number of similar boxes.
I'm running Win2k SP4, Athlon 1 GHz, 512 MB RAM, SB Audigy 2, Radeon 7500, F-Secure VShield
-MacGyver
Reply 1 of 3, by MiniMax
Rank Moderator
Moderator
I have no specific idea on what is causing this, or how to solve it. My only advice is to boot into safe mode, de-install, reboot into safe mode again, and try to install 2.1.0 one more time.
_________________
Reply 2 of 3, by Anon...
I get the same problem in a multi user setup if vdmsound was installed on a different user than you're trying to run it from.
ex.
User A (administrator access) installs VDMsound. Works great.
User B (also admin access) tries to use VDMsound, gets all those errors, starting with the one mentioned above.
Reply 3 of 3, by vladr
Read the post below. Registering ATL.DLL may help.
V.
