First post, by Danfun64
I have a compaq Armada 1750 with an es1869 in it. I am curious as to how you think this sound card compares with dosbox's opl3 emulation. More importantly, I wonder if it's possible to replace the soundcard with something like the sound blaster 16.
Of course it's unlikely, being a laptop, but I am curious...
Reply 1 of 12, by leileilol
It's not a card in that case. It's a chipset.
If it has a docking station you could try shoving your favorite ISA sound card in that, but at that point it's not really a laptop anymore 😀
Reply 2 of 12, by Danfun64
Thanks for the fast reply 😜 In your opinion, how decent is the es1869 compared to the sb16, or do you not know?
Reply 4 of 12, by swaaye
ESS Audiodrive chips are good DOS options. ES1869 is a SBPro2 compatible chip in DOS. Its FM synth is very similar to OPL3.
Some late DOS games support Audiodrive natively and I think that allows 16 bit digital audio like a SB16. 16 bit support isn't super important for DOS games though as not many use high quality samples anyway.
Recordings
https://www.mediafire.com/folder/uc37ntgrkgxh … Card_Recordings
Reply 5 of 12, by Danfun64
It supports PCMCIA, but I have the slot occupied with an ethernet adapter. I should probably get a USB hub and a usb-ethernet adapter for my sole USB port on that laptop (yes, it's new enough to have a USB port.)
When I used my old laptop with Boom, the sound effects seem lower quality compared to modern source ports (even chocolate doom) or running Boom in Dosbox. If I did get a PCMCIA sound card, I would prefer it to have HQ sound effect support.
Reply 6 of 12, by swaaye
For DOS games the ES1869 emulates a SBPro2, meaning digital sound effects will run at 8-bit, 22.05 kHz stereo (or 44.1 kHz mono). In Windows, the ES1869 is a 16-bit, 48 KHz audio chip. So if you can run a Windows 9x port of Doom it should sound as good as a SB16. This is assuming the notebook's implementation of the audio chip isn't particularly poor quality and that could be the actual issue here.
There is a thread on here that looked at PCMCIA sound cards (search should find it).
Reply 7 of 12, by Danfun64
So, what PCMCIA card do you recommend for 16-bit sound effects on DOS?
Reply 8 of 12, by leileilol
I've had issues with some ESS chipsets running sound quality at half frequency than requested in DOS before.
Reply 10 of 12, by Danfun64
kolano wrote:
There are USB soundcard options, but those won't provide DOS compatibility
I specifically want 16-bit sound effects with DOS compatibility. Even if I did know about USB sound cards, they have no relavence to my issue.
Reply 11 of 12, by lolo799
New Media's Wavjammer or Sound/SCSI card, but not all DOS games support them directly.
Reply 12 of 12, by PeterLI
Get a desktop PC.
