First post, by MrEWhite
Hi, I am trying to play the game Blood (By Monolith) and when I try to play it with the Midi music, it always finds a CD, even with no CD in the drive, it says Audio Tracks found as the game is loading yet I have no cd in both of my CD drives. Is there any fix for this?
Reply 1 of 12, by Davros
dos or dosbox ?
Reply 2 of 12, by leileilol
the real thing
Debian's fucked
Reply 3 of 12, by ElectricMonk
There could be a no-cd patch online somewhere. You'll have to find it, since I suspect linking it here would violate the TOS.
Reply 4 of 12, by MrEWhite
I mean, the game runs. But no music plays, CD music plays with the CD in the drive. But without the CD no music plays, even Midi. And I run DOS. Windows 98.
Reply 5 of 12, by filipetolhuizen
Try booting directly to DOS without loading CD-ROM drivers.
Reply 6 of 12, by MrEWhite
This works, it's only if I have my CD Drives enabled.
Reply 7 of 12, by filipetolhuizen
This behavior is normal for this game. I also experience it. Maybe an unfixed bug...
Reply 8 of 12, by MrEWhite
Alright. So I would have to use DosBox on my main rig to use midi?
EDIT: I found a workaround. If you launch the game with the "-nocd" parameter through a shortcut Midi works!
Reply 9 of 12, by filipetolhuizen
At least they thought about it. 😀
Reply 10 of 12, by MrEWhite
This only happens with SB16 Emulation drivers loaded... Hm.
Reply 11 of 12, by MrEWhite
Well, running CD drivers (oakcdrom.sys) through config.sys and autoexec.bat that work in DOS for me fix it.
Reply 12 of 12, by MrEWhite
Still having this issue, for some reason in DOS mode when booting Blood says "CD-ROM drive initialized, Audio tracks found." Loading the standard oakcdrom.sys.
