First post, by brandsizzle
- Newbie
Hey all, I've started getting into building some older systems this year and due to some lucky local hauls I got a good amount of items but can't seem to pick what would work best in combination.
I'm looking to build 2 retro systems, a "time machine" per Phil who frequents these forums which is a P-166 (I might lower it to a P-133) and will be my main machine while I also found a new in box 486 DX-66 which I want cause it holds a place in my heart. The wife wants these systems built so I have to make a call.
I have the following cards to split between those 2 systems, I do have a Roland SC-7, SC-55, and MT-32 (Gen 1) for midi.
Awe64 Gold
Several Sound Blaster 16's (CT1730, CT1740, etc...) some with the hanging note bug and some without
Sound Blaster Pro 2 (CT1600)
Sound Blaster Pro 1.5 (CT1320U with the CMS Chips)
Roland MPU-IPC-T (Was going to use Softmpu but got lucky with a Kijiji ad and picked this up)
I was going to put the awe64 and sbpro 2 in the time machine but now that I have the mpu-ipc-t the sbpro 2 can't use the line-in, and the 486 was going to be the SB 1.5 and SB16.
