Reply 5460 of 58562, by kithylin
obobskivich wrote:
7950GX2 is officially 143W TDP (it could not physically draw higher than 150W with its configuration), however various sources have asserted real-world is more like 110W TDP, and that nVidia over-stated the numbers. My HX 520 has similar specifications to the Antec, and runs QuadSLI just fine. The 9800 and 295 are substantially more power hungry devices.
I know the others are bigger and more powerful.. I just after reading that have always assumed multiple multi-core gpu's generally ain't to be used with multi-rail power units, I never use anything but single-rail units myself and I haven't had issues with any computer in years.
Reply 5461 of 58562, by tokroger
Salvaged this poor thing from scrap today for 10 euros...
Nice basic case. PSU and all drives missing, cover little bended but it could be saved.
That says it all, I think it´s worth of saving
Nice, mint condition P60 SX948, 8 megs of RAM and all seems to be ok. There was heatsink on the CPU which I removed, fan was missing from top of it.
Pity this baby doesn´t have FDIV-bug. But you can´t get it all 😀
These two cards were attached to the mb. Media Magic soundboard and Trident TGU1944 based videocard.
I think i´m going to borrow PSU from one old systems I have. I really going to test if this rig is possible to bring alive!
Reply 5462 of 58562, by Lukeno94
Something you don't see every day - a 60 MHz Pentium. Can't imagine there are really that many of those around, since the faster 486s were quicker and cheaper, and socket 4 was only around for one generation, so you wouldn't have had people fitting the CPUs as temporary solutions either. Intel didn't learn from Socket 4 - Socket 423 showed that.
Reply 5463 of 58562, by havli
Not exactly a retro hardware... but still nice part of my video cards collection.
Reply 5464 of 58562, by PeterLI
Reply 5465 of 58562, by Sutekh94
As somebody who owns a Pentium-60 rig, be prepared to have the temperature of the room you're using that rig in increase by a few degrees or so. 🤣
Seriously, though, those things are absolute blast furnaces. And yeah, the performance is certainly lacking compared to something like a later 486, or, heck, even a Pentium-75. All that being said, you don't see Socket 4 rigs every day, and I hope yours works!
My YouTube | My DeviantArt
Reply 5466 of 58562, by tokroger
Seriously, i doubt if it works, but hey, i've got something to do couple of days 😀 and P60 is somekind of start of an era. And it's so beautiful...
Reply 5467 of 58562, by jwt27
Nice find, tokroger! That mainboard is the Batman's Revenge, which I still think is a really cool name for a board 😀
I have the same board here somewhere with an FDIV-bugged P60, but IIRC it doesn't work anymore.
Reply 5468 of 58562, by tokroger
Batman's Revenge...that sounds so cool 😀 didn't knew there was board named like that but Google proved You right. Everyday I learn something new i suppose 😁
Reply 5469 of 58562, by obobskivich
There's no reason to avoid a multi-rail unit with a multi-GPU card or multi-GPU system, as long as the PSU itself is high quality. And remember some "multi-rail" units are not actually separated internally (some of the Corsair units are like that, for example).
Reply 5470 of 58562, by MMaximus
tokroger> nice find! If the board still works, you might have to replace the Dallas RTC as it seems it's dated 1995 from the pics.
Hard Disk Sounds
Reply 5471 of 58562, by nforce4max
Finally found another Thermaltake Xaser case, its the Xaser III for my Athlon MP build for $45 but is missing the 3.5 drive rails (ouch).
Reply 5472 of 58562, by Unknown_K
I have one of those, mostly because they can fit an EATX motherboard. Nice case and the Thermaltake lights up. Are you using the fan console (I removed mine)?
Reply 5473 of 58562, by Unknown_K
Most P60/66 CPUs died because OEM's used a passive heatsink (they glued on) and a case fan to blow air over it. The case fans got dusty and died so the CPU fried. Packard Bell sold a ton of those systems and most are dead (mine still works). The CPU was the last of the 5VDC ones and the die was huge, they also sell well for gold scrap (PPRO being the #1) so there are few around anymore.
Reply 5474 of 58562, by jwt27
From what I've heard, if you have a P60 with the FDIV bug, you can still send it back to Intel to get a NIB replacement 🤣
Reply 5475 of 58562, by ODwilly
http://www.ebay.com/itm/181395145055?_trksid= … K%3AMEBIDX%3AIT just bought this on a whim, anybody have any ideas on why it has a "vga terminator" and any information on this specific card? I have been digging around and have yet to find anything out about it.
Reply 5476 of 58562, by keropi
^ who knows if this "terminator" was used with the card... most likely it was just something that fitted the connector and the seller attached it, don't power the card with that thing plugged in the vga port. It could be a dummy connector to fool the card there is a monitor connected or it could be a firework starter 🤣
Reply 5477 of 58562, by obobskivich
That card shouldn't need a VGA terminator with a monitor attached, but here's a basic explanations of what a VGA terminator does (and they are indeed a real thing):
http://www.cables4computer.com/Cabling_Produc … Terminator.html
http://www.mp3car.com/general-hardware-discus … is-present.html
http://www.overclock.net/t/384733/the-30-second-dummy-plug
You should have no problems booting the card with the connector attached; the card will think it has a monitor connected to it, but there's nothing to receive the output signal. I'd remove it and hook the card up to a monitor, personally. 😊
No idea about the specific card itself though. Got a bigger picture? (ebay won't let me blow the image up - it just wants to tell me the item is already sold).
Reply 5478 of 58562, by Unknown_K
I have an IBM video capture card (PS/2 era) that needed a terminator on the XGA video card so it would work through its VGA connector.
MCA M-Motion:
"System Board Video Termination
Whenever a color display is attached to the VGA Display connector, the VGA Terminator plug MUST be installed in the system board display connector. Otherwise, the PS/2 VGA adapter will not recognize that a color display is attached to the M-MVA, and all VGA and video output will be displayed in monochrome (B&W). (Ed. Does this apply to a Base Video adapter like the XGA-2?)"
Reply 5479 of 58562, by jwt27
Some professional monitors/projectors don't have internal termination resistors (or a switch to disable them), to allow daisy-chaining multiple monitors. You would use a VGA terminator (basically three 75-ohm resistors) at the end of the chain to correct the impedance mismatch.
If you've ever used a VGA splitter with normal 75-ohm terminated monitors, you would know what an impedance mismatch looks like 😉
