Reply 5800 of 58184, by keropi
^ kudos on the A1200 purchase .
Playing games on the 1200 is very easy and can be done from the workbench , there is a tool called WHDLOAD (www.whdload.de) that converts booter floppy games. All you need is some fastram for the machine, there are 100eur accelerators made in 2014 that offer 64/128MB of ram, more than you need and with a nice speed boost. amigakit.com/vesalia.de/amibay.com are your friends on that 😉
there is a also a scandoubler that makes the A1200 output dvi/hdmi...
Reply 5801 of 58184, by easy_john
keropi wrote:
Playing games on the 1200 is very easy and can be done from the workbench , there is a tool called whdload
To be honest, you need to solve a lot of issues that would happily use the Amiga, playing games from workbench:
- fastram or 020/030 accelerator to be able use whdload and forget about loading games from floppy (from 150 eur for modern accelerator)
- scandoubler, to be able use modern monitors (about 150 eur)
- ide2cf adapter and CF, instead of harddrive, fast and silent hdd (10-20 eur)
- ps2 mouse adapter (after decade using optical mouse you can't satisfied using mechanical mouse anymore) (10 eur)
- pcmcia network on pcmcia to CF - a way to transfer files to amiga (10-20 eur)
Pentium2 450/256mb/4gb/ati rage 128+voodoo2/SB awe32 8mb+db50xg/GUS PnP 8mb/TB Tropez 2mb
486 DX2-66/32mb/8gb/tseng4000 2mb/SB 16+WB/GUS 1mb/LAPC-I
286 12mhz/4mb/512mb/Vga 1mb/SB 2.0+Covox
PegasosII G4 / Amiga 4000 / Amiga1200 / Amiga 600
Reply 5802 of 58184, by keropi
^ you just described the "classic pimped A1200 setup" 🤣 🤣 🤣
Assuming though that you have jwt27's setup as he described it all you need is fastram and a storage device.
Everything else can be omitted in order to save money until you decide you want to pimp the setup: use the 15khz monitor and winuae to setup your new hdd and transfer files. Expanding amigas is an expensive hobby 🤣
Reply 5803 of 58184, by pewpewpew
jwt27 wrote:
The Amiga is a pretty cool machine, but really weird to get used to if you've never used one before (like us).
Fab machines, still missed. Also still have the 1080 monitor doing service in the Playstation corner. But specifically here's a nice link a friend just sent me, covering FPS on the Amiga.
Doomed: The Embers of Amiga FPS
https://www.youtube.com/watch?v=Tv6aJRGpz_A
Reply 5804 of 58184, by Stojke
That floppy cable, it hurts
Reply 5806 of 58184, by easy_john
keropi wrote:
Expanding amigas is an expensive hobby :lol:
Yes, i know: https://translate.google.com/translate?sl=aut … 2%2F&edit-text=
Reply 5808 of 58184, by kithylin
soviet conscript wrote:
it looks the same and does the same thing but the m919 cache stick is specifically for that 486 motherboard any other cache stick like the ones you have for Pentium machines can damage the m919 if used in it. thats why its kind of valuable and sought after. the sticks you have are far more common and were for Pentium machines and I think a lot of 90's macs used them to. I don't know how much a generic COAST module goes for but i'm guessing not a ton.
Thanks for clarifying. I was just curious and thought others could use to know too, so asked here instead of PM.
Reply 5809 of 58184, by schlang
According to my knowledge, emulating a MT-32 is a tricky thing, because one allows (via sysex messages) to upload new sounds to […]
According to my knowledge, emulating a MT-32 is a tricky thing, because one allows (via sysex messages) to upload new sounds to MT-32 memory, thus giving it a new, different sounding, and quite a few games used this feature (notably from Sierra, Dynamix, Lucasarts)
And no devices that are compatible on hardware level with MT-32 can understand these sysex data.
Besides, devices that claimed MT-32 compatibility sometimes employed a complete MT-32 sound banks (like Roland Sound Canvas), but sometimes, they just changed sequence its own sound banks, to match MT-32 sounds sequence.
That's why a lot of games, that were designed for MT-32 (and came with their own sounds) sounds odd on other sound devices.
We've Been SLAPPed
PC#1: K6-III+ 400 | 512MB | Geforce4 | Voodoo1 | SB Live | AWE64 | GUS PNP Pro
PC#2: 486DX2-66 | 64MB | Riva128 | AWE64 | GUS PNP | PAS16
PC#3: 386DX-40 | 32MB | CL-GD5434 | SB Pro | GUS MAX | PAS16
Think you know your games music? Show us: viewtopic.php?f=5&t=37532
Reply 5810 of 58184, by SquallStrife
easy_john wrote:
To be honest, you need to solve a lot of issues that would happily use the Amiga, playing games from workbench: - fastram or 020 […]
Accelerators are overrated, way less necessary in an A1200 than in, say, the Apple IIgs. A trapdoor RAM card of 4MB or more is more than enough to play all the classic games using WHDLoad.
A scandoubler is handy if you don't have a good RGBs monitor. C= 1084s and Sony PVMs can be had cheaply, work natively, and give the authentic experience. If you're just going to play your system upscaled on a big screen, you may as well use an emulator.
Everything else I agree with, but they are cheap to do, so why not.
NB: Not that I wouldn't take an accelerator if I could get one! I just mean they're not necessary to have fun with the A1200. You can play Cannon Fodder, Alien Breed, Lotus 2+3, Chaos Engine, etc etc etc, all from WHDLoad, with just a 4MB trapdoor RAM card.
Reply 5811 of 58184, by keropi
^ yes true. all you need is some fastram for whdload to work. All amiga games (except later 3d ones - that are crap on the amiga anyway) are designed to work with either an 68000 +1MB ram (OCS/ECS games) or the onboard 020 +2MB ram that the A1200 has (AGA games). CPU-wise you are set 😉
In case someone wonders you need the extra ram for use with whdload , the floppy->hdd conversion has it's requirements. A whdload game behaves like a native workbench application (the equivalent of a native windows games) , you start it from the gui and when you quit it you are back at the gui in the state you left it. The original games were floppy booters.
Nowdays there is the 100eur ACA1220 with 128MB of ram and a 16 or 25mhz (IIRC) 020. It makes the machine more enjoyable. Plus a 4/8MB fastram expansion hovers at the ~50eur range, imho it does not worth it.
Reply 5812 of 58184, by PeterLI
Reply 5813 of 58184, by retrofanatic
some more random eBay pick ups this week...
Another Audigy...
The attachment $_57 (1).JPG is no longer available
ATI X1300 PCI-e video card...
The attachment $_57 (5).JPG is no longer available
GeForce 9500GT...
The attachment $_57 (6).JPG is no longer available
Another Extron Crosspoint switcher...this one has no audio switching capability, but I had to get it...for only $9, can't go wrong...
The attachment $_57 (7).JPG is no longer available
A couple new in box PIII 800 CPUs...
The attachment $_57 (11).JPG is no longer available
Reply 5814 of 58184, by retrofanatic
An ATI all in wonder 9600 PRO (this is my second boxed one I own now). I used this card in my main rig setup (s478 Gigabyte 8KNXP and ASUS P4C800) for over 7 years before moving on to a Core 2 Duo just 3 years ago and it never let me down. I do prefer NVidia for the most part, but I have a soft spot for this card...
The attachment $_57 (12).JPG is no longer available
yet another KVM switch...I'm going to have to quit buying these things...space is becoming a premium
The attachment $_57 (3).JPG is no longer available
picked up this 6800GS PCI-e, just because I already had one and wanted to maybe try them out in an SLI setup one day, but they are kind of useless since I have much faster cards for my Core 2 Duo setup. Do these cards offer better compatibility with certain games? What's it good for since I can't use it for Win98?
The attachment $_57.JPG is no longer available
Reply 5815 of 58184, by ReeseRiverson
Hmm, looking at that KVM switch, makes me realize I need to get a nice switch for all my systems. Especially if I want to try to use the same monitor and keyboard for a lot of systems. 🤣
Reply 5816 of 58184, by retrofanatic
Yes, they come in very handy...it's nice to have everything connected, so you don't have to mess around with switching cables all the time.
I find a lot of the KVM switches I get now for a lot of time for less than $10 at a local recycler. They are very expensive new and for a while it was hard for me to find any at a reasonable price.
One of the reasons I have so many now is because I can get them for so cheap now, but also it's because I am always looking for one that does not degrade the quality of the image too much.
As you may know, if you are looking for KVM's, keep in mind that many have a limit of the resolution you can feed through it. Some KVMs I have only allow up to 160x768 or 1600x1200 and some will allow up to 2048x1536 resolutions, (which is the most I would ever need for my modern systems).
Reply 5817 of 58184, by kithylin
<snip picture>
The 6000 line of cards are fully compatible with Win98se, For the AGP versions.. but not the PCI-Express versions (no PCI-Express based systems ever released chipset drivers for Win98 that I'm aware of).
Reply 5818 of 58184, by fyy
No fan? My little 9600 XT had a fan!
Reply 5819 of 58184, by ReeseRiverson
I have the same All In Wonder card he does, and there is no fan on mine either.
