First post, by EleqTriziT
EleqTriziT
Offline
Has anyone used Telemate successfully? I can dial an IP or hostname successfully and connect, but once connected Telemate doesn't relay my keystrokes to the server.
I even started a short Perl-based server script that echoes client keystrokes to the server's screen and I don't see anything, where as if I telnet to the Perl server with regular ol' telnet I can see what I type just fine.
Side note about dialing in Telemate... I have to use "atdt192.168.0.1" because "atdt 192.168.0.1" won't work. The space matters, apparently.
agustin
