First post, by Evert
- Member
New year, new rig. Through time, I've accumulated the following:
Processors:
- 2x AMD K6-2 400MHz AFQ
- 1x AMD K6-2 500MHz AFX
Graphics Cards:
- Gigabyte Rage 128 Pro AGP 4x
- Connect3D Radeon 7000 AGP 4x
- EVGA GeForce 6200 AGP AGP 8x
- Sapphire Radeon 7000 PCI
- GeForce FX 5500 AGP 8x
Motherboard:
- AOpen AX59 Pro Super Socket 7 ATX Motherboard (I have a Generic ATX backplate that fits it perfectly)
ISA Soundcards:
- Creative Labs SoundBlaster AWE64 Value
- Genius Yamaha YMF-19E-S
Hard Drives::
- 2x 80Gb Western Digital SATA2 (Jumper set to SATA 1 Mode)
- 1x 80Gb Maxtor IDE Hard Drive
- 1x 10Gb Maxtor IDE (not sure if this one actually works)
Hard Drive Controllers / Adaptors:
- 2x Syba Silicon Image SIL-3512 (3112a) 2-port Sata Controller Card
- 1x IDE -> SATA Adaptor
Memory (DIMM):
- 1x 64Mb Kingston PC-100
- 3x 128Mb Hynix PC-100
- 1x 128Mb Samsung PC-100
Power Supplies:
- Rosewill RV-350 300W ATX 1.3 (it's brand new and has a -5V line)
- AOpen ATX-300GU (old with a noisy fan, but the capacitors are very good quality and the soldering is top notch)
Floppy Drives:
- 3x Mitsumi Beige 1.44Mb Floppy Drives
- 1x Sony Black 1.44Mb Floppy Drive
- 2x GOTEK Floppy Drive Emulators (Black)
Optical Drives:
- 2x LiteOn IDE Super Multi Drives
- 1x Gigabyte 16X DVD ROM Drive
- 1x Beige Sony CD-RW
I still need to buy a case, but I'm leaning towards the Cooler Master K280, since it offers a decent ammount of airflow at this price point. I was thinking of buying 2x Corsair AF-120 Quiet Edition Red LED fans (one for exhaust at the back and one for intake at the front). I also have an old Socket 7 heatsink (with the 50mm fan missing) and a brand new Startech 50mm Socket 7 cooler. It's definitely going to be a challenge to build this thing, since the power supply will be mounted at the bottom, but I still have a couple of ATX axtension cables that I can use. So hopefully it will be okay.
What I'm really concerned about is the actual speed of my processor. Now, I know that the K6-2+ and K6-3+ CPUs are better choices because you can dynamically adjust the multiplier with SetMul. Unfortunately, after waiting for months I could just not find one. It's not a complete disaster, since I can still manually set it using the multiplier switches on the motherboard itself. If I understand the multiplier switch correct, I can only really use 2.5-3.5 without encountering any interesting problems (for example the 2.0x and 6.0x mode is the same), so if I understand this correctly, this means that the lowest possible speed that I can achieve is 2.5x66Mhz = 166Mhz. Now, do I have to vorry about setting the voltage lower or higher or should I just leave it at the CPU's default level?
The oldest games I plan on playing is something like Space Quest 1 and the "latest" is something like Blood / Shadow Warrior / Tomb Raider 1. I've studied the manual and it looks like I can only switch the "L2" or motherboard cache off. What kind of speed reduction can I expect from that? I've watched some of Phil's videos and read some of the topics here, but I could only find data on where both L1 & L2 are disabled and one where just L1 is disabled. I know that the K6-2 chips run very hot, so I'm expecting to see temperatures of about 45-60 degrees on full load if the CPU is running at 400-500MHz. If I underclock it a bit, will I be able to run the CPU fan at 5V/7V (hopefully resulting in less noise)? Is it even worth all the effort or should I just not worry about it and run everything at default speed?
I plan on running either MS-DOS 6.22 / MS-DOS 7.1 / FreeDOS 1.1 on this system. I suppose I could install Windows 98SE and play some early Windows games on it too, but we'll have to wait and see. Thanks for all the help and feedback guys.
