First post, by Max01
I have Aladdin and Lion King installed on my pc !i tried to open it using windows (error message : you need to run it in 256 colours )
i am using win xp so i changed the colour settings with a right klick on the file but it didnt work!
then i used the emulator but it said "this is windows nt executable"
i dont know what it is...
anybody can help me please !!!!!
thx 4 ya support
max01
Reply 1 of 13, by Harekiet
Rank DOSBox Author
DOSBox Author
Well don't run the windows versions of the games
Reply 2 of 13, by Max01
yeah but it doesnt run under windows because of the 256 colours!!
Reply 3 of 13, by Harekiet
Rank DOSBox Author
DOSBox Author
Well that may be but then it still won't help running windows programs under dosbox
Reply 4 of 13, by Max01
mhhhhh i dont know if it is for windows but the filename is lionw.exe
and there is no other exe file!
Reply 5 of 13, by PPaladin
The fact that is it literally saying it's an NT exec. is a small hint that it might very well be a Windows exec.
Just search the inet: There's bound to be a Dos version available somewhere...
Reply 6 of 13, by mirekluza
Rank DOSBox Moderator
DOSBox Moderator
Moving elsewhere ...
Mirek
Reply 7 of 13, by Xian97
Aladdin and Lion King had both separate DOS and Windows versions. The filename lionw.exe with the w at the end indicates that you have the Windows version. As others have said, you will need to find the DOS version to use with DosBox.
Reply 8 of 13, by ChaosFish
Do you use WinXP? If so, run it in 256 color compatibility.
Reply 9 of 13, by Max01
i tried the aladdin playable demo (DOS VERSION)
installation works fine but the game doesnt work!
i always get an xms error or something like that.....
i have heared that this windows version only runs in win 98 /95 ... is this correct?
Reply 10 of 13, by Max01
is there a way to buy / get the aladdin dos version?
Reply 11 of 13, by ChaosFish
The underdogs.
Reply 12 of 13, by wildstar
:neutral:
Max01 I have the full version copies of both Lion King & Aladdin for the PC. These games will not work on Windows XP. They only work on Windows 98 or real MS DOS. I haven't tested them out on DOS BOX yet but they will probably work on DOS BOX as well.
Email me if you are interested in trading for these games.
These games are hard to find on the internet.
Reply 13 of 13, by eL_PuSHeR
I remember to have played Aladdin (floppy version) under WinXP, but i am not entirely sure. I will test it later, when i arrive home (i'm at work now).
