First post, by ripa
edit2: just enable Catalyst A.I. instead of the following hack 😉
Posting this in case it helps someone else in the future.
I couldn't get Soldier of Fortune II working on my computer (Windows XP, Radeon HD4650). Both single-player and multi-player executables would crash to desktop without any error pop-up immediately after the startup console window. According to web search results, the culprit is an AMD video driver update related to OpenGL (keyword: OpenGL extension limit), but that it is supposed to have been fixed in a newer version. All solutions I could find for this problem were unhelpful (upgrade/downgrade drivers or use some outdated OpenGL DLL).
Fortunately, I found a really easy fix that has worked for me:
- open SoF2.exe in a hex editor
- find the string beginning with "GL_EXTENSIONS:" (without the quotes)
- REPLACE (do not ADD or REMOVE) the five ASCII characters following the colon with five null bytes (= bytes with value 0, actually replacing just the first byte should be enough)
- repeat this for the "WGL_EXTENSIONS:" string
- save and repeat the same procedure for SoF2MP.exe
- enjoy(?) the game
Explanation:
- the game queries the OpenGL driver for a list of OpenGL extension names, of which there are more in newer drivers
- there seems to be a buffer overflow error related to printing the list (or a long string), which causes the crash
- terminating the print format string early with null bytes prevents the print function from parsing the %s specifier and triggering the error
edit: This might work for other Quake 3 / Id Tech 3 engine based games as long as the executable is unpacked.
Reply 1 of 5, by Gamecollector
Q3 games suffer from the OGL extensions limit? Strange.
The proper way is to replace %s to %p.
If the game uses PunkBuster or something similar - it will fail the integrity check. Then you must use the most proper way - add this game to atiogl.xml and enable Catalyst A.I.
This is the entry in atiogl.xml for my Radeon HD2600 Pro Agp:
	<!-- SoF II - soldier of fortune II - Double Helix-->
<profile exename="SoF2.exe">
<maxExtensionsStringLength>3900</maxExtensionsStringLength>
</profile>
Reply 2 of 5, by leileilol
I would it expect the game to fall under that "Compatibility Profile" extension list it does for some older games. Tried renaming sof2.exe to quake3.exe?
Debian's fucked
Reply 3 of 5, by Davros
Works with amd (6950, cats 14.12)
does nvidia still have the limit opengl extensions in the nv control panel ?
Reply 4 of 5, by ripa
Gamecollector wrote:
Q3 games suffer from the OGL extensions limit? Strange. The proper way is to replace %s to %p. If the game uses PunkBuster or so [
</profile>
Well hit me with the dummy stick, Catalyst A.I. fixes Sof2 without this exe patching hack. I didn't know if affects OpenGl compatibility. I had disabled it because I thought it just overrides the anti-aliasing/anisotropic filtering settings per application.
Also, thanks for the tip about atiogl.xml. I didn't know you could adjust OpenGl compatibility settings per application.
Reply 5 of 5, by Gamecollector
Atiogl.xml is used only if Catalyst A.I. is on. It looks like the SoF2 entry was already here for HD4650, you just disabled it.
