First post, by CrazyTerabyte
I have some old programs I made using Turbo Pascal. Some of them did not work correctly. The most important problem is about function "86h", from "int 15h".
The following code is equivalent to a delay function:
procedure makepause(ms:Word); assembler;
asm
mov ax,1000;
mul ms;
mov cx, dx;
mov dx, ax;
mov ah, 86h;
int 15h;
end;
The ms parameter is the time to "sleep", in miliseconds.
Unfortunately, it looks like DosBox ignores this.
I attached the little game I made in Turbo Pascal, long time ago. Source and binary included. It is needed to decrease CPU Cycles until this becames playable.
    minhoca.zip
    14.69 KiB
    195 downloads
    Game that uses function "86h" of "int 15h". Source code (Turbo Pascal) and binary included.
Reply 2 of 3, by priestlyboy
It should at least since I just tested it and works just fine in the DOSBox CVS (the CVS sourcecode available at their sourceforge.net/projects/dosbox page.)
I make builds of it on a weekly basis abouts. See my sig.
BTW: My highscore with your little game came out to be 180. Spanish text but still playable :p.
Ieremiou
Helping Debug DOSBox.
Reply 3 of 3, by CrazyTerabyte
Yes, it works on CVS, but didn't work on 0.61 release.
BTW, it isn't Spanish, it is Portuguese (although there are only a few words in whole game). Thanks for playing my humble game! 😀
Don't tell anyone, but the maximum score is 255 or 254, because it is the maximum size of "worm" (I wanted to use only one byte to store it). 😉
