reactos
First post, by idice
ok can u guys get this thing to work on react os. im trying to swich to that and a lot of people are nt clone www.reactos.com im trying to install it but i cant it seems like is trying to start but then it gowes away pls do soemthing this program rocks
Reply 1 of 2, by mirekluza
Rank DOSBox Moderator
DOSBox Moderator
IMHO reactos is at present state just an interesting experiment and I doubt whether it ever becomes really useful.
As for DOSBOX running on reactos - since they are emulating Windows NT, DOSBOX should be able to run there *when* it gets to usable state (if ever ...).
Otherwise you can take DOSBOX sources and try porting. But frankly I do not see any point in doing it.
Mirek
Reply 2 of 2, by Srecko
If SDL works on reactOS, then dosbox should work too (with much of the stuff in config.h disabled). I would start with MinGW.
