Far Cry
Reply 20 of 395, by mirh
BuckoA51 wrote:
Interesting findings there, I will need to look into this and update my own article. I didn't come across the 1.6 patch last time I played the game (a few months back), I wasn't able to get HDR working at all but everything else seemed ok.
If you are talking of this, be aware that game not only support EAX 2, but advanced HD to (which may be either 3 or 4). Also, 7.0 is the maximum
And there's 3Dsoundback for Realtek chips and Xear3D/GSDX for cmedia/asus cards
It wouldn't even be bad -I guess- if you mentioned the unofficial Enhanced Content Patch for 32 bit systems
pcgamingwiki.com
Reply 21 of 395, by BuckoA51
Got a link to that patch?
Actually planning an overhaul of the legacy sound advice on my site to mention things like IndirectSound and 3Dsoundback. Not having access to that hardware means it's difficult to do tutorials but still should mention it.
play-old-pc-games.com
Reply 22 of 395, by mirh
http://farcry.filefront.com/file/FC_64ecu_to_ … onversion;50861
To test ALchemy just check here. The others are somewhat briefly explained on PCGW (yeah, it's definitely not really well elaborate.. but you are free to contribute 😁)
And remember that albeit IndirectSound correctly restores DS hardware buffers (thus multichannel/positional audio on newer systems), EAX is not implemented (support is just faked)-
pcgamingwiki.com
Reply 23 of 395, by Davros
mirh wrote:
advanced HD (which may be either 3 or 4).
It's eax 5
Reply 24 of 395, by Robin4
Do you really need a Intel Core Duo 2 to run this game? As i look on the back of the DVD case, i see that it needs:
Windows: 98-2000-ME-XP
1GHZ processor
256MB of Memory
Geforce 2 64MB / ATI 8500
And there is also an AMD64 logo on the back.
Reply 25 of 395, by mirh
Davros wrote:
It's eax 5
Today that can even mean EAX5.. but back in 2004 EAX5 wasn't anything
pcgamingwiki.com
Reply 26 of 395, by awgamer
Robin4 wrote:
Do you really need a Intel Core Duo 2 to run this game? As i look on the back of the DVD case, i see that it needs: […]
1GHZ processor
256MB of Memory
The target would be 60/120/144(depending on your monitor) minimum FPS for optimum performance.
At 1600x1200 4x aa 8x af, a 6800 Ultra on an a64 3400+ only averages 38 FPS: http://www.pcstats.com/articleview.cfm?articleid=1578&page=8
1600x1200 4x aa 8x af, 7800gtx sli on a fx-55 has a minimum of ~44 fps: http://www.pcper.com/reviews/Graphics-Cards/N … iew/Far-Cry-v13
1600x1200 hdr + 16x af, a c2d x6800 with an 8800 ultra does a minimum 61 FPS: http://www.xbitlabs.com/articles/graphics/dis … -extreme_8.html
Setting to hdr ingame instead of aa is better as you can use post processing aa utilities like fxaatool to have both, though there's a possible performance hit so might need a little bit more cpu or gpu than a x6800/8800 ultra.
Reply 27 of 395, by awgamer
An 8800 ultra is a little faster than a 9800 gtx: http://www.hwcompare.com/3846/geforce-8800-ul … force-9800-gtx/
http://www.techpowerup.com/reviews/ASUS/GeFor … 85_MARS/12.html
The difference between 1680x1050 and 1600x1200 is about the same between an 8800 ultra and 9800 gtx such that the fps should be about the same, so going from the x6800@3.0 to a 920@3.8 gives about +25%. Subtract 25% from the gtx 285 result, it'd do ~300 fps on an x6800, or 2x an 8800 ultra.
gtx 480 on an x6800, about 344 fps: http://www.techpowerup.com/reviews/NVIDIA/GeF … 0_Fermi/14.html
Reply 28 of 395, by jonpol
(EAX emulation is being worked on though, and progress is being made! Someday... 😊 )
Reply 29 of 395, by PhilsComputerLab
Put in another hard drive in my main desktop PC (i7 with GTX660), installed XP, and using the latest Nvidia driver the land mass reflection show up just fine:
Reply 30 of 395, by mirh
philscomputerlab wrote:
Put in another hard drive in my main desktop PC (i7 with GTX660), installed XP, and using the latest Nvidia driver the land mass […]
Should we assume then that any driver under XP just shows it properly?
pcgamingwiki.com
Reply 31 of 395, by PhilsComputerLab
Hmm that might be a bit bold, but I would tend to agree 😀
Reply 32 of 395, by mirh
XP graphics dlls could be tried on vista and 7 then..
pcgamingwiki.com
Reply 33 of 395, by BuckoA51
Hey Phil, did you ever get the 64 bit patch/content working with the community patch? Since the community patch needs 1.4 and 64 bit only installs on 1.33 I guess they're not compatible?
Reply 34 of 395, by PhilsComputerLab
Pretty much. I don't think the 64 bit patch is worth it. 1.6 is my preference. The FCOM mod is a bit extreme and I really don't like the aim down sight weapons they added.
Reply 35 of 395, by BuckoA51
That's what I suspected, thanks.
Reply 36 of 395, by mirh
There's 64bit content port for 32 bit too
pcgamingwiki.com
Reply 37 of 395, by boxpressed
I just received the retail version (1.0) and loaded it on my "high-end" XP system: AMD Phenom II x4 940 / Geforce 9800GT / 4GB DD2 667 / XP Home 32-bit SP3
Just a few seconds into the actual game, the screen goes black, but I can still hear the sounds.
I patch the game to 1.4, and after a few seconds of gameplay, the screen freezes and then reappears with artifacting.
I decide to uninstall the 332.21 drivers because I finally found older versions. I installed 195.62, which appeared about a year after the 9800GT, I believe.
This time, I could play a little longer, but the screen froze again after a few minutes.
I am running 1600x1200 with high settings (no AA).
I'm pretty sure this is just a Far Cry issue because Doom 3 plays just fine on this system. All suggestions welcome!
Reply 38 of 395, by PhilsComputerLab
There is an issue with newer drivers, but just textures being affected. Not crashing or anything like that.
The loading bug, with the black screen, is quite common under Windows 7, but I've never had it under XP.
Patch 1.4 makes enemies see you, and shoot at you, through tents and plants. So I recommend the http://www.farcrypatch16.de/
Maybe it fixes your other issues as well.
Reply 39 of 395, by boxpressed
Thanks, I'll try it. I seem to need a password to download. Do you happen to know it?
If it doesn't work, I may do a fresh install of XP. I hate having to uninstall new drivers to install old ones; I'm never sure what is left over. Plus, I needed to install SP3 and NET Framework 4 to use the 332.21 drivers. Maybe I won't have to install those to use 195.62.
