First post, by Guest
I'm a Gentoo Linux user. I emerged the DOSBox 0.61 ebuild. SDL compiles cleanly, while DOSBox doesn't. It says:
g++ -DHAVE_CONFIG_H -I. -I. -I..  -I../include   -march=pentium4 -O2 -pipe -fomit-frame-pointer -fexpensive-optimizations -frerun-loop-opt -frerun-cse-after-loop -ffast-math -s -I/usr/include/SDL -D_REENTRANT -c -o dosbox.o `test -f 'dosbox.cpp' || echo './'`dosbox.cpp
g++ -march=pentium4 -O2 -pipe -fomit-frame-pointer -fexpensive-optimizations -frerun-loop-opt -frerun-cse-after-loop -ffast-math -s -I/usr/include/SDL -D_REENTRANT -o dosbox dosbox.o cpu/libcpu.a debug/libdebug.a dos/libdos.a fpu/libfpu.a hardware/libhardware.a gui/libgui.a ints/libints.a misc/libmisc.a shell/libshell.a -lasound -lm -ldl -lpthread -L/usr/lib -Wl,-rpath,/usr/lib -lSDL -lpng -lz -lSDL_net -lGL
gui/libgui.a(sdlmain.o)(.text+0x1c5f): In function `main':
: undefined reference to `SDL_NumJoysticks'
gui/libgui.a(sdlmain.o)(.text+0x1c6f): In function `main':
: undefined reference to `SDL_JoystickEventState'
gui/libgui.a(sdlmain.o)(.text+0x1c7b): In function `main':
: undefined reference to `SDL_JoystickOpen'
gui/libgui.a(sdlmain.o)(.text+0x1c88): In function `main':
: undefined reference to `SDL_JoystickNumButtons'
gui/libgui.a(sdlmain.o)(.text+0x1c9b): In function `main':
: undefined reference to `SDL_JoystickNumAxes'
gui/libgui.a(sdlmain.o)(.text+0x1ca9): In function `main':
: undefined reference to `SDL_JoystickName'
collect2: ld returned 1 exit status
make[3]: *** [dosbox] Error 1
make[3]: Leaving directory `/var/tmp/portage/dosbox-0.61/work/dosbox-0.61/src'
make[2]: *** [all-recursive] Error 1
make[2]: Leaving directory `/var/tmp/portage/dosbox-0.61/work/dosbox-0.61/src'
make[1]: *** [all-recursive] Error 1
make[1]: Leaving directory `/var/tmp/portage/dosbox-0.61/work/dosbox-0.61'
make: *** [all] Error 2
Can someone help me, please? Thanks in advance.
Reply 1 of 4, by prompt
This looks like joystick support is not enabled in your libsdl. Execute 'emerge -pv libsdl' and see if the 'nojoystick' useflag it set.
Reply 2 of 4, by Guest
LibSDL was already installed, so Portage said nothing about it. However, you're right: when I installed LibSDL I set nojoystick. I'm now trying to reinstall it.
Reply 3 of 4, by Guest
Great...it works. Thank you! Now I can make my dream come true: finally see the end of Dune! 😀
Anyway, a request to the authors: can you add compile-time joystick enabling?
Reply 4 of 4, by Harekiet
Rank DOSBox Author
DOSBox Author
Send the request to the sdl people to not completely remove all the joystick code when the joystick is disabled but just supply the dummy drivers 😀
