First post, by jennifer3
When I have DOSBox up and I walk away from my computer, it won't hibernate. I'm certain it is DOSBox that is doing this, because if it's NOT running then my computer goes into hibernation just fine after so many minutes.
This happens when the DOS prompt is showing and when I'm running a program (usually one that I wrote using Turbo C).
I understand there's some system call a program can make that turns off "hibernatability". Should I try to intercept this call and no-op it? (I'm trying to ALLOW hibernation not stop it.)
I'm using Debian Linux 6 (Wheezy) with the MATE desktop.
Jennifer
