First post, by Nic-93
Does anyone here know were to i can get my hands on a cd image of the raceing game from 1995?
Reply 1 of 15, by dexter311
There's a good chance there's a CD image in the GOG.com release of the game.
Reply 2 of 15, by Nic-93
hmm, actually, i tried that and i got a freedos installation.
if you can get it out from the folder, i would be pleased.
Reply 3 of 15, by PhilsComputerLab
Unfortunately not. While Screamer 2 has the files to create a full installation CD, Screamer doesn't and you need to burn the image to a disc as well as copy the game files to a folder on the hard drive and edit a few configuration files.
I ended up buying the full Installation CD from eBay.
While many games from GOG.com allow creating a full installation CD, quite a few don't.
Reply 4 of 15, by Nic-93
I dont really want to go thou all that just to get a game running it would be easy with a simple iso version.
Reply 6 of 15, by leileilol
Though in Screamer's case you need to make a BIN/CUE from the CD. 😜
Debian's fucked
Reply 8 of 15, by Nic-93
i had tried honestly, didnt had so much luck with the bin and cue stuff, i followed the configuration routes and it didnt work for me.
Reply 11 of 15, by PhilsComputerLab
http://www.philscomputerlab.com/playing-dosbo … -gaming-pc.html
After making the disc you need to also copy the game folder and then edit one of the text files to change the path. The game will then work on your retro PC.
Reply 13 of 15, by Nic-93
I was just asking for if i could get a image of the dos game screamer, the gog copy crashes when im on tournament mode.
Reply 14 of 15, by Nic-93
I actually found a screamer cd image in english, so the situation is good now, it apearently came from somekind of russian site.
