Reply 80 of 3184, by Marmes
shock__ wrote:
My workflow basically goes like this:
Scan both sides (1200dpi), correct the scale in photoshop so vias match up perfectly or at least very close, convert to 2 color black & white, convert to .dxf, convert with "Eagle Power Tools" to a script that draws said black & white image to a dummy layer, start redrawing 😀 One major issue is getting the scale right.
Once everything is redrawn, start deriving the schematic using Eagle's Electric Rule check so layout and schematic become consistent (that part is really tedious).
Circad does all that inside 😐 Would you send me the raw scanned pictures? So I can show you?
I also need dimensions of board. And that's it 😀
I forgot to ask, is it 4 layers or 2 layers?
Cheers!
Reply 81 of 3184, by shock__
Marmes wrote:
Circad does all that inside :| Would you send me the raw scanned pictures? So I can show you? I also need dimensions of board. A […]
Cheers!
2 layers ... if it was 4 layers (like the original GUS PnP) the project almost wouldn't be worth it (okay, there's a GUS PnP for 220€ on eBay currently, I guess I would undershoot that).
Raw scanned pictures are 260MB - a bit too large for my line to send. Would a 300dpi version work for you as well?
I'm certainly gonna take a look at CirCARD tho.
EDIT: Bit of progress - http://i.imgur.com/ZmmZcTb.png
EDIT2: Bit more progress - http://i.imgur.com/gVT24C5.png (won't get updated in the next week, vacation time for now)
Current Project: new GUS PnP compatible soundcard
[Z?]
Reply 82 of 3184, by PhilsComputerLab
Just upload to DropBox and then share the link.
YouTube, Facebook, Website
Reply 83 of 3184, by Marmes
Dropbox is cool!
Reply 84 of 3184, by Synoptic
How hard would it be to make the card PCI/PCIe compatible ? (not counting the drivers, just the HW part of it)
Reply 85 of 3184, by Marmes
It's not impossible, but not worth the trouble. Cheaper to get a 486 or pentium computer
Reply 86 of 3184, by shock__
PCIe seriously? Just use DOSBox. No need to invent the wheel a second time and claim it's a steamroller.
[Z?]
Reply 87 of 3184, by shock__
Just got a quote from one supplier - $19 per set of custom chips. I guess that's not as cheap as I had hoped, but still is cheap enough to make this project happen.
[Z?]
Reply 88 of 3184, by Marmes
Oh! let me tell you, I think IW= interwave so IW78c21m1 is a rebranded memory from MX, not FIFO as I thought, and it might contain info for wavetable. Maybe it's a flash with wavetable data. 1mb to be more precise.
Could it be a 29f800? Could you tell me where is VCC and GND on that IC?
Thanks!
Reply 89 of 3184, by shock__
Sounds like that is clue worth chasing 😀
I'll try to derive a pinout when I have access to the card again.
[Z?]
Reply 90 of 3184, by Marmes
If you see a db50xg, you can find the same chip, but rebranded for yamaha.
Reply 92 of 3184, by shock__
I'll check into those once I get back to the card ... so far everything you said made sense ... and would explain the optional DIP footprint on the Gravis GUS PnP.
Is there an easy way to read out those ROMs?
[Z?]
Reply 93 of 3184, by Synoptic
I have a GUX Max 1.8. If I can help in anything non-destructive, let me know.
Reply 94 of 3184, by Marmes
yah, they are not protected 😀 They can be read easy or not if they changed pins. maybe we can use a flash by changing the circuit a bit
Reply 95 of 3184, by Marmes
A Gus Max does not use interwave chip, so it won't be necessary to use it 😀
Reply 96 of 3184, by gerwin
Thanks!
Should contain this 1MB set:
http://www.voicecrystal.com/services.htm
Our 1 Meg & 4 Meg sets (vers. 3.0) on the AMD Interwave chip-set line of products; Reveal Wave32 Extreme Gravis (now Ken […]
line of products;
Gravis (now Kensington) Ultrasound Plug-n-Play
Core Dynamics - Dyna Sonix - Wave & Pro Sound Cards
Their 4 Meg General Midi Sound set version 4.1 is very nice, but not free.
Reply 97 of 3184, by Marmes
They offer the sets to upload in ram, not in rom I think.
Reply 98 of 3184, by gerwin
-There is a 1MB ROM on my GUS PnP clone. And one can load a 4MB set in RAM (GSFULL4M.DAT/GSFULL4M.FFF).
-I do not have any 1MB set as a DAT/FFF file for RAM.
-Voice Crystal soundsets where present in ROM in the Turtle Beach soundcards like the Maui and Rio.
So I just figure the GUS PnP 1MB ROM is the same story...
Reply 99 of 3184, by Marmes
is there a way to dum those roms? Are they protected? They are just like db50xg and other daughterboards.
