Reply 6840 of 59336, by brostenen
Yeah... People (the seller/shop) just point mindless at it and mechanically shout...
"Butt... It's from Apple!" 😁
Reply 6841 of 59336, by Lukeno94
If I had the starting bank balance, I could probably make a fair bit of cash fixing up and selling on Macbooks... if only. Even the spares systems tend to go for a lot of money.
Reply 6842 of 59336, by sliderider
torindkflt wrote:
Not really "today", but this past weekend I found this glorious thing at a Goodwill store in Omaha.
You bet your sweet patootie I bought it! I have not yet had an opportunity to really try it out though, primarily because I currently do not have any bootable 5.25 floppies.
You better open that up quick. They have a barrel battery inside.
Also, is that a 6300 or a 6300+? The 6300 is an 8086 machine. The 6300+ is a 286.
Reply 6843 of 59336, by Sutekh94
Just won a Dell Inspiron 8100 off of eBay for a little over $30. Not in the best condition but at least it does work.
My YouTube | My DeviantArt
Reply 6844 of 59336, by Unknown_K
Cyrix 1995 sample CPI with bent pins.
G5F8540A, I assume its a 5x86 100?
Will know if it works in a few days when it gets here.
Reply 6845 of 59336, by PcBytes
jwt27 wrote:
At a decent refresh rate? The 201P I had barely managed 75Hz or so at that resolution.
90KHz/60Hz refresh rate. And it's a crisp image. Also it shows the POST sequence of my PC,displaying it as fast as my 22" Horizon LCD.
Reply 6846 of 59336, by RacoonRider
kithylin wrote:
Gigabyte GA-7N400 Pro2 v2.0 Motherboard. nForce2 Ultra-400 chipset, with the dual-port IDE RAID onboard, and SATA RAID onboard. […]
Gigabyte GA-7N400 Pro2 v2.0 Motherboard. nForce2 Ultra-400 chipset, with the dual-port IDE RAID onboard, and SATA RAID onboard. Snagged it for $16.22 + free shipping, comes with (unknown) CPU and heatsink. Seller claims it works, was pulled from working machine so I'm hoping it does. Seller's pictures are used here. I think these are the latest and highest-end motherboards for Socket-A. I bought it personally because back when Socket-A came out, this was one of those setups that I saw on the display wall at my local Fry's years ago and dreamed of owning, but never did get to because they were like in the $250 region new and I never could afford one. And then as time went on, eventually they were discontinued, and then eventually we couldn't even find em used, at least not at decent prices. Traditionally they've been in the $150+ range for nice boards like this even used. So.. this was sort of an impulse buy.
/snip/
Slightly Bigger: http://www.outfoxed.net/GA-7N400.jpg
EDIT: Fixed a typo
Nice board! I've got a 7n400s, a very similar one with one less memory slot and two less IDE channels. A solid performer 😀
P.S. Your nickname reminds me of her somehow
Reply 6847 of 59336, by Lukeno94
Make sure you've got a hard drive fitted, otherwise it won't detect the fixed optical drive. Otherwise, those are very nice laptops! Be aware that the CMOS battery is built into the palmrest (of all things), and the metal underpart of the palmrest needs to be removed to get at it - when you re-fit that metal piece, it needs to have the tabs slid under the bottom of the palmrest (you'll see what I mean if you take it apart), or the lower mouse buttons will just flop around.
Reply 6848 of 59336, by torindkflt
It is a standard 6300 as best as I can determine, I have not yet opened it up to physically examine the innards, and with no available boot disks I currently am unable to go beyond POST.
I have considered replacing the battery, as I do recall seeing a mention online somewhere that the 6300 is known to utterly drop dead at even the slightest hint of battery leakage. Would it be beneficial for me to retrofit it with a sealed replacement like the one shown below, or just replace it with the same type of battery that it currently has? The local BankruptShack currently has both types on clearance for 25 cents each.
The attachment TL-5242-W.jpg is no longer available
Reply 6849 of 59336, by kithylin
RacoonRider wrote:
Nice board! I've got a 7n400s, a very similar one with one less memory slot and two less IDE channels. A solid performer :) […]
No relation what so ever, my name has nothing to do with whom ever that is, I don't even know who it is.
I came up with this name years ago by mixing and matching parts of 'dragon names' in the index in the back of Anne McCaffrey's book "The Dragon Riders of Pern".
Reply 6850 of 59336, by smeezekitty
<deleted>
Reply 6851 of 59336, by easy_john
Found nice desktop case for my 486-vlb project, with nice "188Mhz" 7-segment display. ~ 8 usd on local forums.
IMG_4168.JPG. IMG_4169.JPG.
IMG_4172.JPG.
Like new, even with a nuts and bolts, and display connection scheme.
Pentium2 450/256mb/4gb/ati rage 128+voodoo2/SB awe32 8mb+db50xg/GUS PnP 8mb/TB Tropez 2mb
486 DX2-66/32mb/8gb/tseng4000 2mb/SB 16+WB/GUS 1mb/LAPC-I
286 12mhz/4mb/512mb/Vga 1mb/SB 2.0+Covox
PegasosII G4 / Amiga 4000 / Amiga1200 / Amiga 600
Reply 6852 of 59336, by Skyscraper
This post will be slightly more off topic than usual.
Nothing in this post is retro what so ever. Buy hey, it isnt a car! 😁
My system in my signature is a great system when it comes to heating up my chilly apartment during Swedens very long and cold winters.
Its not so great during Swedens short but very hot summers so I use to use one of my spare single CPU socket 1366 rigs during the summer so my AC can keep up.
I thought of building a new summer rig just to test some newer hardware as I diddnt own any newer stuff than socket 1366 systems.
I happend to see LinusTechTips 300$ PC challange and I thought it could be fun to see what I could get with little money from Swedish Ebay (Tradera).
https://www.youtube.com/watch?v=x1JA24KCAjE
All the gear below totalled 2880 SEK = ~300 Euro = A little over 300$
We have 25% VAT in Sweden so the stuff was much more expensive new than it would have been in the US so I think its fair.
CPU. I7 2600K, This was a steal, I got it for a very cheep buy out price 1 minut after it was listed 😀
Motherboard. MSI P67A-GD65, This was also a buy out with a very fair price.
Memory. 4X 2GB Samsung DDR3. (I bought loads of these Samsung 2GB DDR3 modules for ~2 Euro each some time ago, like a big box full of modules)
Videocard #1. Gigabyte GTX580. This card I bought sometime ago for ~50 Euro, it wasnt even a snipe.
Videocard #2. Gigabyte GTX580. This card I got for cheap sold "as is", previous owner spilled coke and other stuff on it so its sticky and dirty.
Storage. OCZ Revodrive3 X2 240 GB. Buy out shortly after it was listed. I got it for a fraction of what the drive is worth.
PSU. Corsair AX850. I got it for cheap as its defect, When it has been disconnected from the grid you have to turn the power switch on the PSU back and forth until it wakes up
Cooling. Zalman CNPS10X Extreme. I got it for next to nothing.
Case. What ever I will find in the electronic waste container.
Its crazy what you can get for a few hundred Euro these days 😁
I did also buy some other nice stuff which did not fit into the 300 Euro challange.
I7 3770 (not the K version but should do ~4200- 4300 MHz all cores at stock voltage)
Gigabyte G1 Sniper2. This motherboard is brand new but a "sample product". It has been on show in a window. The store sold this 400 Euro board for 100 Euro 😀
4x 4GB Dominator GT 2133 MHz CL9 DDR3. Samsung revision D, pretty much the best DDR3 memory in existance. These were not very cheap 😀 ~120 Euro.
Reply 6853 of 59336, by Robin4
easy_john wrote:
Found nice desktop case for my 486-vlb project, with nice "188Mhz" 7-segment display. ~ 8 usd on local forums. http://kawai.spb. […]
IMG_4172.JPG.
Funny, i have got that same desktop case here..
Reply 6854 of 59336, by Gamecollector
6 expansion slots? IMHO, too few. The standard is 8.
Reply 6855 of 59336, by badmojo
Cool! I love AT cases. I had one with a similar internal layout and got the impression that it was for later, smaller AT boards, like PCI socket 3's and later. Anything bigger clashed with that bar running down the middle.
Looking forward to seeing the completed build - I'll be interested to see what sound options you go with.
Reply 6856 of 59336, by easy_john
Hope, that I found time this month and complete my other 486 setup, focused on sound. Stay tuned :)
Reply 6857 of 59336, by RacoonRider
Got myself a complete PC for $5. The specs are far from impressive, it's a P166MMX in some cheapo 430TX board, 32MB SDRAM, S3 Trio64V2/DX with 4 RAM sockets, two of which are populated. I bought it mainly because of the case. It's a crocodile type desktop with 2-digit MHz display that actually says "MHz" after digits! It's in nice shape, the only drawbacks are yellowed front and lost rubber pads. It's also got a nice L-shaped AT PSU and a 5.25" drive!
I think I'm going to use this case for a 386 build in the distant future and sell the mobo\CPU\RAM set for small money to someone who needs this stuff, I've got too much already.
Reply 6858 of 59336, by keropi
^ what a nice dog!
is it trained to protect retro hardware? 😁
Reply 6859 of 59336, by badmojo
Very cool dog and an ace case! My beloved childhood 486 came in a case very similar to that flip-top bad boy and I loved how easy it was to pop the hood and get my hands dirty. Funny you call it a crocodile because it did bite me a couple of times, the sides are like guillotines.
