First post, by Roman78
I'm running w2k on a HP Thin Client. Now I installed a 24" display whit a resolution of 1920x1080. But I can't chose that resolution. First I would say... not supported, but than I found even higher resolutions like 1920x1200 and some 20something by14something. The onboard graphic card I use is a SIS Mirage.
So is there a simple way to set the resolution to the right one? Could not find anything for w2k....
