OK, so given the difficulty of finding cache, I'm not even going to consider it for now. That said, I'll just pick up EDO RAM for the board, and should a cache module become available down the line, I'll look for FPM at that time.
A few other things I'd like some direction on:
1) I have a 486DX-50 processor (not DX2). As I understand it, things get unstable with 40 and 50MHz bus speeds, so I plan to clock the processor to 33MHz. Will I have any problem with that?
2) A PCI video card seems the logical way to go, but I'm not sure which models to look for if I want to retain driver compatibility with old OS's such as DOS 6.22 and Win95. Any suggestions on the video card? There is one free VLB slot, so a VLB video card is a possibility, I suppose.
3) For a hard drive, I'm thinking of using a 4.3GB uw SCSI drive I have, and an adaptec 2940u2w that I also have. Both are just in a drawer at the moment. As best as I can remember, the 2940u2w shouldn't have any trouble in a DOS environment, but I'm not 100% sure. Can anyone chime in on that? If I don't use the SCSI, I'll need to pick up an older IDE drive and use the motherboard's onboard controller. Does anyone have any specific IDE drive suggestions? I'm guessing anything under 8GB should be fine. Or do I need to stay under 512MB?
4) For RAM, if I recall, 72 pin simms will run fine in pairs, no? Was it only 30 pin simms that needed quartets? My tentative plan is to get a couple 32MB EDO Simms. Does 64MB sound like a reasonable amount of memory?
Thanks
