First post, by grazzy
Just curious how well dosbox would perform with an amd64 under gentoo for example?
Quite considering getting one, and would like to know if dosbox is supported before getting one. 😀
Thanks.
Thanks.
I am not sure whether it is possible to compile DOSBOX for 64 bit processor, but 32 bit version will work in any case.
I do not think that you will get any significant performance increase - DOSBOX performance depends chiefly on processor speed.
Mirek
it works under amd64. at least under gentoo linux
Water flows down the stream
My system will compile and run DosBOX fine, but I'm getting crashes. Here is the text from the command line:
CONFIG: Using default settings. Create a configfile to change themALSA:Client initialised [65:0]MIDI:Opened device:alsaFatal signal: Segmentation Fault (SDL Parachute Deployed)
And a backtrace:
#0 0x0000002a9597055e in pthread_getconcurrency () from /lib/libpthread.so.0#1 0x0000002a959703e0 in pthread_getconcurrency () from /lib/libpthread.so.0#2 0x0000002a9596fc78 in pthread_create () from /lib/libpthread.so.0#3 0x0000002a95b59c94 in SDL_SYS_CreateThread () from /usr/lib/libSDL-1.2.so.0#4 0x0000002a95b59b1a in SDL_CreateThread () from /usr/lib/libSDL-1.2.so.0#5 0x0000002a95b5ab8a in SDL_SYS_TimerInit () from /usr/lib/libSDL-1.2.so.0#6 0x0000002a95b5a4df in SDL_TimerInit () from /usr/lib/libSDL-1.2.so.0#7 0x0000002a95b098c4 in SDL_InitSubSystem () from /usr/lib/libSDL-1.2.so.0#8 0x0000002a95b0996a in SDL_Init () from /usr/lib/libSDL-1.2.so.0#9 0x000000000044f0c1 in main (argc=-1073745808, argv=0x8) at sdlmain.cpp:914
hmmm do you have an amd64 version of sdl installed ?
I recall being many problems with that.
I have an a64 3400+, and I couldn't be happier with performance! I can actually run xwing smoothly! 😁
I'm running the win32 version though, hopefully someone will make a win64 version when the OS comes out!
All my libraries should be 64-bit as Gentoo compiles them and everything. I haven't rebuilt SDL in a while, so I'll try that.
try running dosbox as root.
Same error as I posted above.
