OpenAL entirely broken on X-Fi
First post, by jwt27
My X-Fi card does funny things in ioquake3 games when OpenAL is enabled. It sounds like this: sample from ioRTCW
Random distorted sounds everywhere, sounds cut off short, hearing sounds from far away like they're right next to me, and in the menu (pressing esc in-game) there's a constant stream of both distorted garbage and random in-game sounds.
However, when OpenAL is disabled and I use ALchemy instead, it works fine but 3D positional audio seems less accurate.
Any ideas what could cause this?
And, just to make sure this isn't some bug in ioquake3, are there any other native OpenAL games I could try?
possibly relevant information:
Card: X-Fi Elite Pro
OS: Windows 7 x64
Chipset: Intel X79
Driver: daniel_k's Support Pack v3.0
Mode: Game mode with EAX and CMSS Headphone enabled
Reply 1 of 29, by obobskivich
ALchemy uses OpenAL, so its being rendered in OAL there. If I remember right BioShock can use OAL if you want another test.
Reply 2 of 29, by jwt27
Yeah, that's why I figured it might be an ioquake-specific thing... Thanks for your suggestion, I'll try Bioshock but downloading the trial version will take a while.
Reply 3 of 29, by mirh
Bioshock OAL info here
For the remainder... Are you using latest OAL 2.1.0.0?
Also I'd recommend newer daniel_k drivers
You should really not resort to ALchemy if the game has native OAL though (quality wise, theoretically)
pcgamingwiki.com
Reply 4 of 29, by Davros
Did you install openal or openal soft ?
Reply 5 of 29, by jwt27
And I just updated to 3.2... This 3.3 pack wasn't on his website already. Oh well, thank you 😀
I should add, I performed a clean install since the 3.2 installer had no upgrade option.
Thanks, will install these too. But, isn't this included with the drivers already?
I didn't install anything specific but I assume daniel_k's pack includes the right version of OpenAL. ioRTCW came with OpenAL-Soft DLLs, which I removed.
Reply 6 of 29, by mirh
Maybe this is the problem..
I mean, it's not like open source developers could really work with creative's openAL fork in mind.
I'd ask them if I were you
pcgamingwiki.com
Reply 7 of 29, by jwt27
OpenAL = OpenAL, right? The API should be the same regardless of the renderer used. OpenAL-Soft is just a software renderer for those who have no hardware 3D support.
Reply 8 of 29, by obobskivich
Technically yes, but in practice no. Creative "closed" OpenAL sometime ago (v1.1+), so there exists both their modern, maintained, but proprietary implementation alongside variants (like OpenAL-Soft) that are based on the same FOSS foundation from Loki, and follow their own development trajectories independent of Creative Labs.
Reply 9 of 29, by mirh
The fact is, that openal-soft is based on old code forked years before the actual "official" and proprietary creative implementation.
On the other hand, at least this open source implementation is still developed at least, so it may have new features not present elsewhere.
TL,DR i'm just unsure.. and you'd have better to test both
pcgamingwiki.com
Reply 10 of 29, by jwt27
So, I've installed the latest driver now, with the latest OpenAL dlls, and... nothing changed. 🙁
Bioshock finished downloading late last night, and seems to work okay. The EAX effects sound good, no glitches as far as I could tell, though its 3D positioning seems very vague and disorienting.
Also tried rtcw with OpenAL-soft, and did notice a few glitched sounds but nothing as bad as on the X-fi. A few sounds looped while they shouldn't and some were cut off early. So it might very well be bad implementation on ioquake's side.
I did notice an error message when entering \s_info in the console. Now how do I copy/paste this here?
mirh wrote:
This site is not very helpful, misleading at best.
Reply 11 of 29, by swaaye
I tried SOF2 the other day on my X-Fi Ti. That's Quake3-based too. Its EAX mode is some early version of OpenAL and it was quite messed up on the X-Fi. Audigy has some problems like this too. Fallout 3 with Alchemy doesn't work properly for example. FEAR also has positioning and occlusion problems with Alchemy.
One thing that seems to work well is to just run old games on Windows XP with older drivers.
I think it's pretty clear that the APIs and drivers changed over time and altered expected behavior. You can go back to Windows 98 games where EAX for those often doesn't work right on NT-based drivers.
Reply 12 of 29, by jwt27
Does SOF2 have its own OpenAL implementation (not based on ioquake's)? I think I have this game somewhere...
Reply 13 of 29, by swaaye
Yeah it has an "EAX" mode that seems to be OpenAL based.
Reply 14 of 29, by jwt27
Okay, I tried SOF2 briefly and it sounds fine to me. Procmon confirms this game loads the OpenAL DLLs. In what way is it messed up on your card?
And I just remembered, the community patch for Unreal adds an OpenAL option. This sounds good too, aside from some occasional clicks and pops, which as I recall happened on XP with DirectSound too. Overall, this OpenAL thing is a massive improvement over the original, by the way! Positioning is much clearer, sounds no longer cut in/off suddenly, and the reverb effect sounds much better.
Anyway, I think I can safely call this a bug in ioquake now...
Reply 15 of 29, by mirh
jwt27 wrote:
It says that if OpenAL is unavailable it will use DirectSound3D instead. If even that is missing, of course you have the usual crappy audio implementation that all older games have under Vista.
Still, the point is that the best solution is openal.
What does ALCapsViewer report?
Wait wait wait. I tried both and they sound massively better with ALchemy (or Xonar GX). What alchemy version are you using? 😒
pcgamingwiki.com
Reply 16 of 29, by swaaye
They do sound better but I remember problems with occlusion. I'm not sure if this was on an Audigy 2 or X-Fi though because I was experimenting with both on Windows 8. Audigy's Alchemy behavior is different than X-Fi's. Both cards work better on XP though IMO.
Reply 17 of 29, by mirh
Are you sure? I thought after daniel_k's fiasco it was the same between the two cards.
Even because if even who uses a Realtek can made it to work... I don't see who's the moron that would block an Audigy
pcgamingwiki.com
Reply 18 of 29, by jwt27
Uh, this is weird. I am 100% sure it said Yes on all extensions two days ago. Now I get this:
<removed>
EDIT: Oh nevermind, the driver was in Audio Creation mode... 🤣
Here's the result in Game mode:
System Information
Report Time: 2015/4/3 16:59:14
BIOS: ACRSYS - 1072009 BIOS Date: 03/19/14 13:26:23 Ver: 04.06.05
Processor: ~3400MHz Intel(R) Core(TM) i7-4930K CPU @ 3.40GHz
Memory: 16 GB
Default Audio Device Name: Speakers (Creative SB X-Fi)
Audio Driver Filename: {0.0.0.00000000}.{5f8baa41-4d14-4bf0-b1d7-14d35bfec3cf}
Audio Driver File Version:
Audio Driver Product Version:
ALCapsViewer Version: 1.0.3.0
OpenAL Components
Name Path Version
OpenAL32.dll C:\Windows\system32\ 6.14.357.25
ct_oal.dll C:\Windows\system32\ 6.0.230.4
soft_oal.dll C:\Windows\system32\ 6.0.230.4
wrap_oal.dll C:\Windows\system32\ 2.2.0.7
OpenAL Devices
Name: SB X-Fi Audio [A000]
Sample Offset: Yes
Linear Distance Model: Yes
Exponent Distance Model: Yes
Capture: Yes
Enumeration: Yes
EAX 2.0: Yes
EAX 3.0: Yes
EAX 4.0: Yes
EAX 5.0: Yes
X-RAM: Yes
Enumerate All: Yes
EFX 1.0: Yes
Sample Offset: Yes
Capture: Yes
Enumeration: Yes
EAX 2.0: No
EAX 3.0: No
EAX 4.0: No
EAX 5.0: No
X-RAM: No
Enumerate All: Yes
EFX 1.0: Yes
Sample Offset: Yes
Capture: Yes
Enumeration: Yes
EAX 2.0: Yes
…Show last 8 lines
                EAX 3.0: No
EAX 4.0: No
EAX 5.0: No
X-RAM: No
Enumerate All: Yes
EFX 1.0: Yes
Reply 19 of 29, by swaaye
It's not blocked. In fact I use DanielK's Audigy Support Pack 4.5 when I use an Audigy 1/2/4 with Windows 7/8. Though there is a newer official Creative driver for Audigy 4 now IIRC.
Alchemy (or the OpenAL driver) just doesn't always work quite correctly. Or perhaps it doesn't behave as some DirectSound3D games expect it to. I'm not the first person to notice this.
