Reply 40 of 43, by jesolo
- l33t
wrote:IIRC (it's been five years), the main issue was that ctrl-alt-del resets didn't work any more when the CPU was in protected mode.
I can confirm that. Ctrl+Alt+Del warm boot doesn't work when in protected mode.
However, I suppose I can just use the reset switch if I want to reboot.
Otherwise, I can probably fall back to revision 3.06 but, then I have the y2k bug again.
