First post, by King_Corduroy
So I was just wondering how many of you guys still use old CRT monitors for your gaming computers either modern or old, personally I still prefer them to LCD even though they may not be as crisp. Also for my old systems it is a must because to me the graphics of the old games often look a little strange on modern screens.
Check me out at Transcendental Airwaves on Youtube! Fast-food sucks!
Reply 1 of 53, by jwt27
Shadow mask master race reporting in. Both for old and new.
Reply 2 of 53, by Robin4
If i find one i would buy them if the monitor is the one iam looking for. LCD can have sharper images, but LCDs does not give me the retro feeling sadly.
Reply 3 of 53, by 133MHz
I do, both for computers and gaming consoles. I hate scaling and lag on my games. LCD monitors are for workstation use.
http://133FSB.wordpress.com
Reply 4 of 53, by badmojo
CRT's for my P4 and older, flat panel for anything newer. One day the supply of decent CRT's still be used up and I'll have to find a modern alternative, but I don't image that will be any time soon. They're still easy-ish to find around here.
At work I use a dual Dell Ultrasharp (@ 2560x1440) setup, and for coding, etc they're just fantastic. I don't think there ever existed a CRT that could compete with them in that situation. But for old school gaming, CRT is king.
Reply 5 of 53, by jwt27
Daily driver:
Reply 6 of 53, by badmojo
jwt27 wrote:
Daily driver
Yar it's not a question of the resolution they can pump out, for mine it's the readability of text at modern resolutions. I'd be crying a river of tears if I had to sit in air con + stare at a CRT all day.
Reply 7 of 53, by Unknown_K
Currently just for my retro machines.
Reply 8 of 53, by RacoonRider
I've got 2 CRTs, both aperture grill. The 17" one is for PII and the 15" one is for everything else. My modern rig has the 19" LCD monitor I bought new in 2006 with my first C2D.
Reply 9 of 53, by PhilsComputerLab
I just don't have the space. I got heaps of LCD monitors lying around though. Must be 8 or 9 or so 😊
YouTube, Facebook, Website
Reply 10 of 53, by Caluser2000
Well I have two Compaq all-in-ones, 486 and P75, with built-in 14" crts. My 386DX25 and 286/12 share an 18" crt. The rest of the 486s, RicPCs, Acorn A4000s, P200mmx and up use an LCD of some description. I have 4 17" crts out in the shed doing nothing.
Reply 11 of 53, by sunaiac
I use a IIyama Vision Master (Race) Pro 410 (17inch diamondtron) on my oldies.
I have a 3DVision 120Hz 23inch LG screen on my modernies.
R9 3900X/X470 Taichi/32GB 3600CL15/5700XT AE/Marantz PM7005
i7 980X/R9 290X/X-Fi titanium | FX-57/X1950XTX/Audigy 2ZS
Athlon 1000T Slot A/GeForce 3/AWE64G | K5 PR 200/ET6000/AWE32
Ppro 200 1M/Voodoo 3 2000/AWE 32 | iDX4 100/S3 864 VLB/SB16
Reply 12 of 53, by jesolo
I also have a couple of CRT monitors that I gathered over the years. From 14" to 17".
Unfortunately, due to space, I currently only use my 22.5" LCD to connect to all of my PCs.
I use a KVM switch for this purpose but, this is not ideal, since I prefer to hook up my older PCs to a CRT monitor.
What I've picked is that I get "interference" on my LCD where the graphics card is either ISA or VLB. I don't have this problem on any PC where the graphics card is PCI, AGP or PCI-express.
Reply 13 of 53, by jwt27
I think that's more of an issue of high-dpi screens in general. Bet you'd say the same if you had a 130dpi LCD 😉
There are some tricks to improve text clarity though, but unfortunately Windows is horribly inconsistent when it comes to text rendering. There's the standard "font smoothing" thing which for most fonts only works at larger sizes, and there is Cleartype which is more consistent but has two different "versions" which work completely different. Cleartype in normal GDI programs always uses LCD subpixel antialiasing and looks horrible on CRT, or LCDs with unusual pixel layouts. For GDI+/DirectWrite there's a much improved version which allows grayscale antialiasing and adjusting the font weight and looks gorgeous if set up correctly. But this only works in a few programs. (Opera 12 with DX11 renderer being the only browser that nearly gets it right)
Reply 14 of 53, by 2fort5r
Several old HP D8902As and Dell M570s that I got from an office clear-out years ago. Before coming to this forum I've always considered them disposable trash... We used to have a huge boiler that was torn out and replaced by a tiny thing that is apparently just as good. The remaining space is full of old CRTs.
Account retired. Now posting as Errius.
Reply 15 of 53, by ratfink
I have:
Vista/XP box on an Iiyama Prolite B1980SD 5:4 LED monitor
Everything else is connected to a Dell U2410 1920x1200 LED monitor:
- via DVI :
Windows 7 [my main PC]
-via VGA and a KVM cascade/chain [two 2-pc electronic/hotkey KVMs feeding into a mechanical/manual 2-pc KVM]:
Win 98 box [socket A, voodoo5]
Dos machine [socket 7]
2000/xp Prescott
[modern] Linux box
The mechanical/manual KVM plugs into a mechanical/manual 2-into-1 monitor switch, that can switch between the U2410 and a 21" Lacie aperture grill crt.
The Win98 and DOS machines are best on the crt.
Reply 16 of 53, by calvin
Never say that to a Trinitron fan.
I myself really like IPS screens, provided they're running at the native resolution. Great viewing angles and colour. AMOLED is great for the blacks, but only really seen on phones. TN can go die in a fire.
2xP2 450, 512 MB SDR, GeForce DDR, Asus P2B-D, Windows 2000
P4 2.6, 1 GB DDR1, Radeon 9600 Pro, P4P800, Windows XP
Alpha 21164, 512 MB, Permedia 2, KZPCM, AlphaPC 164, NT 4.0
Reply 17 of 53, by ODwilly
ViewSonic P75f+ Professional Series CRT for my main machine and a VA912b for my retro fix. Started out the opposite but it ended up that there were no proper 7 drivers for the LCD but there were for the CRT, so go figure. . .
Reply 18 of 53, by tayyare
I have a double monitor system. Asus 26" Full HD LCD and a Samsung, rather odd aspect raito (1680x1050), LCD. The first is directly connected to my daily rig, and the second is connected via a KVM switch as a secondary display to my modern computer, and main display to my three other retro rigs.
I get rid of my CRTs years ago. Good riddance, I have no intention to put these behemoths on my desk again.
GA-6VTXE PIII 1.4+512MB
Geforce4 Ti 4200 64MB
Diamond Monster 3D 12MB SLI
SB AWE64 PNP+32MB
Adaptec AHA29160
3com 3C905B-TX
Gotek+CF Reader
Reply 19 of 53, by F2bnp
I use an Iiyama Vision Master Pro 413. It's a 17" CRT and it can do 1600x1200, which I really dig. If this monitor dies, I have a spare Nokia monitor that can do 1280x1024 with very good image quality. I'd really love to get my hands on a 19" CRT, used to have one that had very low contrast and brightness values and was simply unbearable. Something to do with age, unfortunately 🙁.
My main rig is using a Samsung SyncMaster T240HD, a 16:10 24" monitor. It can do 1600x1200 with black borders, which is uber cool for old games. I can also hook up consoles on this bad boy and they all look pretty darn good at 4:3 aspect ratio. I don't see myself ever throwing this monitor away, it it really is one of the greatest I've ever owned.
I will have to eventually though, IPS panels and FreeSync will eventually force me to make the change. I really don't want to go the 16:9 route 🙁.
