First post, by Sammy
When i select SB16 in mk3 then sound doesn't work (just hear some noise).
But Soundblaster Pro works.
(Dosbox.conf is set to sb16)
I was playing with Sindel but i could not aktivate any finishing move (run,run,block,run,block) (run,run,block,block,run+block)
run=numpad0, Block=numpad2
tried it over 30 times... only babyality move works (run,run,run,up)
Then i tried it with a PS2 keyboard, instead of wireless USB, and then the fatalities work !
Maybe the wireless keyboard is to slow, or it did not regocnize more keys pressed at same time.
