First post, by torindkflt
UPDATE: After perhaps the most intense Googling I've ever done in my entire life, I managed to scrounge up the Toshiba CE Diagnostics I was looking for! They were in a zip file located at http://www.minuszerodegrees.net/manuals/Toshi … ostics_1995.zip.
Because of how bloody difficult it was for me to find these, I have gone ahead and created a couple bootable disk images for future reference in case anyone else looking for these utilities manages to find this posting through Google or other searches. They are located here:
These are MS-DOS 5.0 boot disks with all of the files found in the DIAGS\LOW directory from the "Toshiba_diagnostics_1995" zip file linked above. You can use them to run detailed hardware diagnostics (more advanced than the "TEST", "TEST1" and "TEST3" utilities), perform a low-level hard drive format, and access the BIOS setup. These should work on most (if not all) vintage Toshiba "T-series" portable computers. The contents of both disk images are identical, the only difference is one is formatted for 720KB disks and the other for 1.44MB disks. Note that you MUST use the 720KB image with the T1000, T1100, T1200, T3100(/20) and T3200, as they do not support high-density disks. You can use RAWRITE or other similar disk imaging utilities to write the desired image to the disk.
The following is a complete listing of the disk contents. I am posting this to better help anyone who is attempting to locate these diagnostic utilities by searching for specific file names.
Volume Label: R3CE011/11/1991 05:00 AM 3,430 IO.SYS11/11/1991 05:00 AM 37,394 MSDOS.SYS11/11/1991 05:00 AM 47,845 COMMAND.COM12/09/1995 05:02 AM 10 AUTOEXEC.BAT12/09/1995 05:02 AM 1,250 AUTOTEST.EXE12/09/1995 05:02 AM 93 CONFIG.DAT12/09/1995 05:02 AM 23,298 DESKS4.EXE12/09/1995 05:02 AM 19,298 DYNAS.EXE12/09/1995 05:02 AM 16,384 ERRLOG.DAT12/09/1995 05:02 AM 783 FDCLN.COM12/09/1995 05:02 AM 3,779 FDCPY.COM12/09/1995 05:02 AM 3,877 FDDMP.COM12/09/1995 05:02 AM 2,950 FDFMT.COM12/09/1995 05:02 AM 7,761 HDFAT.COM12/09/1995 05:02 AM 2,733 HDFXT.COM12/09/1995 05:02 AM 117 SETUP1.DOC12/09/1995 05:02 AM 36,334 SETUP1.EXE12/09/1995 05:02 AM 34,317 TESTCE.EXE12/09/1995 05:02 AM 30,070 TESTCE1.EXE12/09/1995 05:02 AM 34,199 TESTCE12.EXE12/09/1995 05:02 AM 36,626 TESTCE16.EXE12/09/1995 05:02 AM 56,409 TESTCE1L.EXE12/09/1995 05:02 AM 49,512 TESTCE1S.EXE12/09/1995 05:02 AM 54,622 TESTCE1X.EXE12/09/1995 05:02 AM 37,026 TESTCE2.EXE12/09/1995 05:02 AM 36,720 TESTCE20.EXE12/09/1995 05:02 AM 33,978 TESTCE3.EXE27 File(s) 640,815 bytes
I hope these come in handy for other fellow vintage Toshiba portable enthusiasts.
Original message, subject "Need Toshiba TESTCE3 utility for T3100/T3200/T5100":
I am in need of the TESTCE3 utility for the Toshiba T3100/T3100/T5100, I cannot find it available for download anywhere. It's used to run more detailed hardware diagnostics beyond what the basic TEST3 utility performs. Would anyone happen to have a copy of this program that they could fire off my way, or an image of the entire Toshiba T3100 technician diagnostic disk?
Thank you.
