Foreshadowing the value of P4 hardware
Reply 100 of 106, by obobskivich
feipoa wrote:
I will ultimately test all the motherboards to determine which boards I can simply put into the recycle bin and to determine which CPUs are functional, however I still only plan on keeping 4 of the 16 Intel 845 boards. I will keep all RAM and CPUs though, as these require little storage volume. I will recap that i865G board since this is the only 865 board in the lot.
I think even my PIII BIOS could see 3.3 - 3.6 GB, depending on which grapics card was installed and how many PCI ROM options were set. If all PCI ROM options were disabled and the onboard video was utilised, I recall the BIOS seeing 3.9x GB. I don't understand why these P4 boards are seeing less than a PIII board.
Which P3 board is that? Is it a server/workstation platform?
Reply 101 of 106, by ODwilly
http://www.newegg.com/Product/Product.aspx?It … N82E16813131504 this is the motherboard I use in my media center pc. The bios only sees 3x of my 4gb of ram but Windows 7 sees all 4gb and utilizes the usual amount for 32bit Windows 7.
Reply 102 of 106, by calvin
Buying an 845GV board would be a stupid idea, as it lacks an AGP slot.
2xP2 450, 512 MB SDR, GeForce DDR, Asus P2B-D, Windows 2000
P3 866, 512 MB RDRAM, Radeon X1650, Dell Dimension XPS B866, Windows 7
M2 @ 250 MHz, 64 MB SDE, SiS5598, Compaq Presario 2286, Windows 98
Reply 103 of 106, by ODwilly
What the motherboard I linked on Newegg? #1 if you would have looked a bit closer it is out of stock (and has been for like 8 years) #2 I was just showing what board I use and participating in the discussion of memory issues/quircks. #3 I picked my board up for free and am pretty happy with it. #4 It is an 865GV thus relevant to the discussion on memory issues 😵
Reply 104 of 106, by feipoa
Weren't all dual PIII Tualatin boards considered workstation or server class boards? In particular, I was referencing my experience with: SuperMicro P3TDDE, Intel SAI2, and MSI MS-9105.
Reply 105 of 106, by idspispopd
feipoa wrote:
I did not have the best success with the HD4350 in my dual PIII-1.4 Tualatin computer for accelerating Flash or other online content. I recall that it only accelerated certain offline HD videos. Used Win7 for that test.
There was a thread some time ago on this subject. It seems you need SSE2 to get flash acceleration, regardless of which video card you have. I suppose your HD4350 would be fine for a P4 machine.
obobskivich wrote:
Interesting about the AGP 4350 - I've often wondered how the AGP-bridged ATi cards handle AVIVO/UVD; I know on the nVidia AGP-bridged cards a number of features are usually disabled vs the PCIe variant (no idea why they do this).
I think I remember reading something about needing a small driver mod/hack for those AGP HD4xxx cards to enable video acceleration. It is not a hardware restriction.
Reply 106 of 106, by obobskivich
Yes, generally. I was thinking of my i815 though, which only handles 512MB. 4GB on a P3 is pretty significant. There are server/workstation SuperMicro, Tyan, etc NetBurst boards that will handle well over 4GB of RAM too.
