First post, by ol2ec
Hi fellow retro fanatics,
I'm trying to install the Compaq OEM version of Windows 3.1, which should contain an incredibly rare piece of software: Xsoft's TabWorks 1.2!
The readme tells me I should put the executables on floppy disks and start by running the first executable. I'm planning on putting the executables in seperate folders, and mounting those folders as floppy disk drives in DOSbox instead. However, I'm not able to run the executables in DOSbox:
Probably this means I'm not running the executable in the correct environment, but I don't know how else I would do it! Do you know how I'm supposed to perform the installation?
