First post, by uniracers
When using the tv2x, tv3x, scan2x, or scan3x scalers for 320x200 games, if I set aspect = true, the scanlines are not even. If I set aspect = false, it looks fine. I assuming this has something to with the way things are scaled. Is there any way get even scanlines with the corrected aspect ratio?
