Reply 40 of 146, by VonHelton
wrote:The passthrough would have been ont of those 15pin conectors though, wouldn't it. I'm wondering whether USB means that now you can just connect up any number of things. I guess there might be trouble with competing versions of control-mapping software.
The CH Products pedals: they say racing or airplane mode. I wonder if that is a physical alteration so that in airplane mode pressing one pedal makes the other rise. Not going to be very realistic otherwise. In a helicopter, you tend to rest your foot on one pedal and do most of the control with the other... although maybe that means I could just map one pedal.
I don't know. Twisty grip sounds good for now, as long as it doesn't rule out adding pedals later.
You *CAN* use peddals with the Sidewinder PP, ja!
I would like to try a set of peddals, but I have yet to see a set under $100(US)!!
