Reply 7900 of 53280, by Lukeno94
HighTreason wrote:
I only allow Windows to see 512MB. The remaining 1536MB are mapped to a ram drive which contains the Windows swap file. The system is exceptionally stable, but if I try doing silly things with the RAM drive it can lock up, rarely though, do I even come close to using even the 512MB of RAM, in fact, barely exceed the first 64MB most of the time.
For more demanding tasks I switch to XP, it's a dual processor rig and I'd rather not lose the RAM, which was why I came up with a creative way of negating the problem.
Sounds like a sensible solution, although I've never fiddled with RAM drives myself. I've never seen 768MB cause any issues for 98 on my Vaio, and I also need the extra RAM for XP. Pretty sure I end up using more than 64MB of RAM in 98 though.
Reply 7901 of 53280, by PhilsComputerLab
ODwilly wrote:
Working on (and may work up a trade for) the ultimate Windows xp AGP setup. 3.4ghz Pentium 4, 4gb of OCZ DDR400, Lian-li case, Gainward 7800GS and a really nice ATX Asus 875P motherboard.
Not wanting to start anything, but how does this compare to a fast Athlon 64 / FX?
YouTube, Facebook, Website
Reply 7902 of 53280, by Nahkri
Cyrix200+ wrote:
Intel i810 chipset
Since it has agp the chipset is not 810 it's 815.
Reply 7903 of 53280, by Cyrix200+
Nahkri wrote:
Cyrix200+ wrote:
Intel i810 chipset
You're right! 😀
1982 to 2001
Reply 7904 of 53280, by MrEWhite
Got a ton of processors.
YypdaF1.jpg?1
2 Pentium III 1.13 GHz
1 1.1 GHz Celeron Socket 370
2 Pentium 166 MHz
1 Pentium 75 MHz
Reply 7905 of 53280, by kithylin
Not trying to start any arguments either, because what I'm about to state is fact and it's out there and been proven years and years ago. But Phil asked so.. Basically the early P4's around socket 478, even the hyper-threaded ones up to 3.4 ghz were easily beaten by slower 2.5 ghz Athlon64 K8 single-core chips (And I mean beaten by a good margin, like +20%). Even the early 775 P4's up to 3.6-3.7 ghz still were not able to compete with the K8's at the time. At least not in WindowsXP Gaming performance with a good GPU.
It wasn't until Intel came out with the Pentium-M and then later Core-2 series that Intel started dominating hard again. In general the P4's are really, really, really hot (And I mean the higher clocked Prescott P4 chips idling on desktop with an aftermarket air cooler @ 55c-60c without even doing anything hot), use a ton of power, and don't perform very well. Where as AMD's K8 chips run cool use a fraction of the power and had significantly higher performance.
I think, at the time, near the end, Intel's Pentium-M and Cedar Mill chips started to compete better, but by then AMD had dual core K8 chips and just dominated even harder.
Anyway, please let's not de-thread this and start big arguments here as it would easily run off topic, the data's out there and it's been posted years ago, go google search for it to see what I'm talking about.
Reply 7906 of 53280, by HighTreason
Nope, that statement is mostly correct. Factor Prescott 2M, Cedar Mill or Presler into it though and the tide begins to turn, but period correctness is debatable for those due to their release dates.
Personally I wouldn't have wanted to run either (Older P4 or a "high-end" Athlon 64) back in the day, both have their own pros and cons.
Reply 7907 of 53280, by sf78
Look at this haul, LOOK!
Reply 7908 of 53280, by sf78
And these!
Reply 7909 of 53280, by sf78
All for 10 freakin €uros! 😊
Reply 7910 of 53280, by Cyrix200+
My AOpen AX59 Pro Super Socket 7 board got here in the mail today. I'll try to get it to work with my Cyrix MII CPU for now, I have some K6-3+ in the mail, but I'm not really sure they are compatible actually. Will have to research 😀
RMroAlxl.jpg?1
h2S0ui5l.jpg?1
1982 to 2001
Reply 7911 of 53280, by Cyrix200+
That's a nice price! How did you manage that?
1982 to 2001
Reply 7912 of 53280, by sf78
Also these keyboards and a bag of 30pin SIMMs (1-4 Mb). These were from a guy who had an apartment full of computer stuff and who sold some of his newer (more useful) stuff on his website. I did offer him more money, but he refused and now I kinda feel guilty about it. 😢
Reply 7913 of 53280, by alexanrs
Did someone just sell a haul with a SB2.0 for 10 EUR??? Wow... I wish I knew people like that
Reply 7914 of 53280, by havli
Asus PC-DL + 2x Xeon 2.4 GHz HT
GeForce 6200 - early NV43 GPU based revision with 128bit DDR
Reply 7915 of 53280, by obobskivich
Depending on whether that P4 is a Prescott or Northwood, and what ODwilly wants to do with it, it will compare decently enough (as in, unless you're just into benchmarking, it isn't significant enough to start drama over imho 😊 ). Northwood should fare a little better (they do a little better per-clock most of the time), and run cooler while doing it. Just from my own testing, P4 3.2GHz Extreme Edition in an 865P with 6800U scores around 22k in 3D01; Athlon64 4000+ in a K8T800Pro with the same card scores around 26k. Neither of those is the absolute fastest for 478 or 939, but they're both "up there." S478 is also easily mated with an 800-series chipset, which have great 9x and 2k/XP support, which isn't as common for 939 systems. Personally I'd take the P4 for a Win9x box, but for XP the 939 system can be faster. It's also worth keeping in mind that while these systems were generally cost-competitive back in the day, P4 hardware is dirt cheap these days (especially if you don't want/need best-of-the-best), whereas 939 hardware can sometimes command silly prices. Basically, to answer your question: both can be awesome. 😀
If you want to read some comparisons with benchmark numbers, these are two that I've kept saved over the years:
http://www.hardocp.com/article/2003/09/23/ath … _vs_pentium_4/1
https://techreport.com/review/7927/the-pentiu … -dfi-855gme-mgf
Both contain Athlon64 vs P4; the HardOCP article also has Pentium 4 Extreme Edition, and the TechReport article includes Pentium M.
Not trying to derail, but just wanted to add to this: Prescott can be absolute space-heaters (I know there was something posted on Vogons recently showing one of them running "business as usual" at >70* C), but Willamette, Northwood, and Gallatin aren't anywhere near as bad - they're generally very comparable to Athlon64 for TDPs and wall power draw (the P4 system I mentioned up above drew around 200W on a ~70% efficient Antec PSU for that test; the A64 drew around 170W on an 80-Plus Corsair PSU).
On the dual-cores - I'd take Pentium D all day over the original K8 duals, because the original K8 duals (Athlon64 X2 for Socket 939) have a timing bug that will cause problems with games, and AMD's "fixer" applet ("AMD Dual-Core Optimzer") does not solve the problem 100%. FWIR this was fixed for AM2 K8 chips, and is certainly fixed in K10 (I've never owned a K8 AM2, but I've played around with a few K10 systems over the years).
Nice. I've got one of those (PC-DL Deluxe 1.05) in my XP Pro system - they're fantastic boards IMO. 😎
As far as "bought these retro hardware today" for me: I finally received my Abit AV8, which came with an Athlon64 3500+ (which was tested, and then put in a box - I've got faster chips 😈 ), and thus far it works great (it produced the 3D01 # for the above discussion even). The uGuru features are a lot more sophisticated than I remember from my AN7; it actually tracks total system power-on hours (mine is a little over 51,000), multiple temperature leads, all of the fans, etc and you can do nifty stuff with that data (you can re-assign fan ports to different temperature leads, change fan ramps, etc) as well as all the normal OCing stuff. Just out of the box quick'n'dirty testing I had it booting at 230x12 and 200x14 on my FX-55 with minimal voltage increase (from 1.5V up to 1.55V); with proper cooling, more than ten minutes of time invested, and so forth it should do quite fantastically. 😀
Reply 7916 of 53280, by Lukeno94
My experience with lower-clocked Northwood P4s (2 GHz and 2.26 GHz IIRC) has been fairly favourable temperature-wise; even with a solid PSU blocking the CPU fan's airflow quite significantly, all that happened was it ended up with the fan cranking right up; the temps were still pretty low. If you're going for Windows 98, you really don't need much more than a basic P4 (or Athlon XP) anyway; almost any game that wants more than that will either run perfectly on modern OSes, or will want XP/run better on XP.
Reply 7917 of 53280, by PhilsComputerLab
Great board!
A few resources and a review can be found here: http://www.philscomputerlab.com/aopen-ax59-pro.html
AOpen tend to put the floppy header in an annoying spot, but otherwise this is a great board.
K6-III+ works fine too 😀
Reply 7918 of 53280, by kanecvr
😁 got a CT4500 (my second one) a CT4380 (AWE64 + IDE), a CT1600, a CT2830 (SB16) and some OPTi isa sound card with an analog devices chip for 15$ today 😁
Also bought another lot of 486 and 386 motherboards + a Millennium (defective unfortunately), a Voodoo 1 made by Biostar, a WDC ISA video card, some unidentified ISA cards, about 21 1MB 30 pin simms + 4x16MB FPM simms of form an individual that deals in electronics recycling. Kind of expensive, payed 100$ for the lot, and he didn't include CPUs this time around (except for two 386SX soldered onto motherboards and one Intel 486DX4 100). Will sort them out an post pictures later.
Reply 7919 of 53280, by ODwilly
Honestly I can not voice any opinion one way or the other as I need to fix it before running into tests. and as others have stated there are lots of benchmarks and facts/opinions around the internet. I have way to many projects to work on but at some point I may benchmark some 754 systems (3000+ semprons and a 3400+ Athlon 64) against this system 😊
