First post, by Mamba
- Oldbie
Hi folks,
I've been struggling with a machine based on a A8N-SLI Premium that won't boot with dual channel memory ECC or not ECC.
I can hear the Speech post say something (can't hear, it seems like a broken radio) and the beep code: 1 Long, two shorts. Forever.
In all cases but one, when I plug a memory bank on the third slot (blue) all is ok, and it recognizes a 2gb ECC stick also.
The seller was so firm about the integrity of the motherboard that I changed the CPU, after you say to that the controller of the memory could be broken, but with another Opteron 180 I obtain the same results... or the same failure.
The only step ahead is that now I can populate TWO Banks, in single channel, so third and four, for a total of 4GB of RAM ECC DDR400.
With this config I can enter a previous installation of Seven Ultimate without problems, except for some drivers not designed for Win7.
The same behaviour if I use NON ECC ram DDR400 or sticks of 1gb ram ECC DDR333, so it is not ECC related at all.
Even reflash 1303 bios and changed VGA with a Geforce 6500, 6600, GTX650.... BTW I changed the PSU also with a solid LC-Power and a XFX (two times).
No changes
I am at a loss, I think it can really be the motherboard, but I fail too see why.
If that's the case, can I use my four sticks of ECC ram on a Abit AN8 SLI?
On the Abit site it says that it can handle 8Gigs, but says nothing about ECC or not ECC.
Or should try something else on the ASUS?
