Reply 8220 of 53152, by Logistics
- Oldbie
wrote:Creative 3D Blaster Banshee 4.99, Xfi Xtreme Music 4.99
Ah, the Xtreme Music--lovely card as they seem to be much more abundant than the other models, but not junk like the... is it the Xtreme Sound that uses the cheap DSP? I forget, but the Xtreme Music is definitely a keeper. Add kX Project for Stereo goodness!
I noticed while searching my local surplus place for the past few years that several of the Xtreme Music cards have heat-sinks on the DSP, but some do not. And I noticed physical differences in the overal thickness of the DSP on several of the boards, showing there are many revisions of this IC. I noticed mine does get hot enough that you don't want to touch it, very long. I probably should add some cooling so the heat-cycling doesn't eventually ruin the BGA setup. Not that I can't run down and get another one for $5. 🤣!
