First post, by PhilsComputerLab
What processor and graphics card are a good match for this game?
It's a bit slow on my Windows 98 machine.
Reply 1 of 25, by leileilol
Period correctly, A P2 450 with a TNT and/or a Voodoo2/Voodoo Banshee will cut it. Unfortunately out of the box, NFS3 is insanely picky of what video cards it can run with.
Reply 2 of 25, by oerk
I remember it running pretty well on a V2, maybe even a V1. Haven't touched the game in the last 15 years, unfortunately.
Reply 3 of 25, by Sammy
i think i was run it on an Amd Athlon 800 Mhz and Geforce DDR.
Reply 4 of 25, by PhilsComputerLab
Hmm I might be having a config issue. The game looks like software render.
CPU is a K6-III+ 400 MHz. Had a Matrox G400, but that card gave me issues with other games, so I will try with a V3 now.
Reply 5 of 25, by Davros
You need at least a voodoo2 with 12mb
the 8mb v2's dont have enough memory for the cockpit view (or is that nfs 4?)
Reply 6 of 25, by PhilsComputerLab
Ok it's working now!
On the CD was a patch for the V3. Followed the instructions (copying 2 files over), set the render to V3 and now it's working well.
A faster CPU is likely needed, but it runs ok.
Reply 7 of 25, by F2bnp
Voodoo 3 and Pentium 3>500MHz will get you out of the slow, 30fps territory I believe. What CPU are you running at the moment?
Reply 8 of 25, by PhilsComputerLab
K6-III+ 400 MHz.
Reply 9 of 25, by Roman78
I used to run it on an AMD K2-500 or was it a 550.... hhmmm or overklocked.... hmmmm I don't remember. But I used a TNT 2 ( I think is was a Viper 770 TNT 2), but I don't remember how much ram it had, must be 8...
Damn 16 years is a long time.
Reply 10 of 25, by F2bnp
philscomputerlab wrote:
K6-III+ 400 MHz.
Yep, that's going to be a bit slow 😢 .
Reply 11 of 25, by PhilsComputerLab
At medium settings it ran quite well, even at 1024 x 768. Quite pleased, but it would be better on a faster system, no doubt.
Reply 12 of 25, by jesolo
I recall running this on my Celeron 566 with a Voodoo 3 and it ran well.
But, when NFS4 came out, I stopped playing NFS3, since many of the tracks and cars (as I recall) where also available in NFS4. Still, very enjoyable to play.
Reply 13 of 25, by Sammy
In the nglide (a wrapper for 3DFX cards) forum is a patch released whitch support widescreen and high resolution for NFS3.
Reply 14 of 25, by Gamecollector
1) NFS3 must be played with the glide renderer. Reasons - the fog and the correct horizon brightness.
2) You can manually force any renderer through command line switches or registry editing. So - you don't need a "supported videocard".
3) 3dfx 1024x768 mode don't use the z-buffer and must be avoided.
Reply 15 of 25, by PhilsComputerLab
Thanks for all the tips guys!
Reply 16 of 25, by swaaye
2MB texture memory means no car dash. Voodoo2 8MB and Voodoo1 4MB.
Reply 17 of 25, by appiah4
Apologies for resurrecting a 2 year old thread but I did not think this warranted its own thread; I'm trying to run NFSIII on a P233MMX+Voodoo2 12MB system and it's incredibly choppy with cockpit view, regardless of whether I go for 640x480 or 800x600. I've tried messing around with the Advanced graphics settings (The rest are set to On or High) and the only thing that kind of helps seems to be the draw distance but changing that to close causes a lot of object pop in.. What could I be doing wrong? What would be the suggested settings for this game on an MMX and Voodoo 2 system?
Reply 18 of 25, by F2bnp
You are CPU limited, which is why you are getting better performance when lowering the draw distance. Try running the game on a faster Pentium 2 or 3 and you'll be much happier with the performance there.
