Reply 8301 of 57981, by Formulator
Robin4 wrote:
moturimi1 wrote:
Check this out and ask for the VGA BIOS. http://www.vgamuseum.info/index.php/cards/ite … r-xl-stereo-f-x […]
Formulator wrote:
ATI VGA Wonder XL24 with Brooktree RAMDAC. Sadly, the card does not work. I would like to find a way to make this functional, as it claims to support dual monitors.
moturimi1 wrote:
Why did card manufacturer combine to cards on one slot card? I think this card was quite expensive in those days.
..even ATI designed such a card: ATI VGA Stereo F/X
Thanks for all the comments. Is it possible to switch of VGA with the ATI VGA Stereo F/X? What about using a second VGA? Which is going to work?
Or just using this website..
http://www.minuszerodegrees.net/rom/rom.htm
It's worth a shot. BIOS version on the XL24 is newer than the one provided here, but it may still work.
Reply 8302 of 57981, by Formulator
Scratch that, the dump that MikeS provided is for the 28800-5 chipset, whereas I have the 28800-6 from the the later XL's and 24's. I will just holdout until I find a proper dump.
Reply 8303 of 57981, by moturimi1
Great, I am collecting ROM-Binaries
I already ask vlask at legacy vgamuseum if it is possible to upload special bios binaries.
He says it takes much effort to coorinate the uploads.
Any other hint how to buit a real database for old BIOS files. Vogons drivers maybe?
I think over time it might be necessary to reflash old hardware!
Reply 8304 of 57981, by lolo799
Bought a Roland DV-7 with the controller, very cheap, for an obvious reason: no hdd included!
The attachment dv7-front.jpg is no longer available
The attachment dv7c.jpg is no longer available
Reply 8305 of 57981, by easy_john
Stojke wrote:
SCSI of course
May be we both wrong.
I've done some other tests in hddspeed - dos utility specially for benchmarking hhd.
+---------------------------Tests Summary Table--------------------------+
|Vendor/Model |Average|Maximal|Average|TTT|Average|Average| Max- |
| | Seek | Seek |Access | |Linear |Linear | Cache |
| | Time | Time | Time | | Read | Write | Read |
| | ms. | ms. | ms. |ms.|MB/sec.|MB/sec.| MB/sec.|
|Non-cache vlb pio0 | N/A | 4.1 | 7.5 |N/A| 2.0 | 2.0 | 2.0 |
|Non-cache vlb pio3 | N/A | 4.1 | 7.4 |N/A| 3.5 | 4.0 | 3.5 |
|Tekram dc680c vlb | N/A | N/A | 7.5 |N/A| 5.2 | 9.5 | 18.6 |
|Tekram dc880 vlb | 3.1 | 3.1 | 11.8 |3.1| 3.0 | 3.2 | 6.3 |
Result - ide dc680 works 2-3 times faster, than dc880 scsi version.
And dc680 cache works close to ram speed (on amd dx4-100 i've got about 30 mb/s ram speed)
May be the reason in time difference between them, scsi is from 1993 and ide from 1995.
Or may be onboard cpu is bottleneck, scsi uses 80186-16mhz, while ide is 80286-16mhz.
(all test performed with modern ide and scsi disks, that can do linear transfer 10-20mb/s)
Cache speed for IDE vs SCSI
680_C.GIF. - 880_C.GIF.
Pentium2 450/256mb/4gb/ati rage 128+voodoo2/SB awe32 8mb+db50xg/GUS PnP 8mb/TB Tropez 2mb
486 DX2-66/32mb/8gb/tseng4000 2mb/SB 16+WB/GUS 1mb/LAPC-I
286 12mhz/4mb/512mb/Vga 1mb/SB 2.0+Covox
PegasosII G4 / Amiga 4000 / Amiga1200 / Amiga 600
Reply 8306 of 57981, by Stojke
I know that I had great results with Tekram DC-300B. It even ran an hard disk drive at 25MB/s in a K6 system.
Reply 8307 of 57981, by luckybob
Found a socket 4 overdrive on eBay. http://www.ebay.com/itm/151736583044
I woke up 5 minutes late to rebid on it, and lost. I sure hope someone here got it. I know I will be kicking my own ass for the next few days over this.
Reply 8308 of 57981, by sprcorreia
easy_john wrote:
Anybody know, where to get AZtech drivers for all cards?
Directly from them:
ftp://ftp.aztech.com/support/DOWNLOAD/sg
Reply 8309 of 57981, by easy_john
No, you can't. For DC-300 you limited to drive and to cache by 16-bit ISA speed, that cant be faster, than about 8 MB/s.
https://en.wikipedia.org/wiki/List_of_device_ … ates#Main_buses
So if you get a 25 MB/s, that mean that you measure cache in ram.
Reply 8310 of 57981, by Stojke
I am pretty sure it was 25MBs. It was the fastest Windows 95 ever installed on my computer.
I tested the hard disk, IBM UltraStar 4GB, with MHDD and it worked at least 4x faster than with other controllers (AMD SCSI in Vectra).
Reply 8311 of 57981, by kithylin
easy_john wrote:
No, you can't. For DC-300 you limited to drive and to cache by 16-bit ISA speed, that cant be faster, than about 8 MB/s. https:/ […]
Most IDE VLB controllers have software drivers you can load (TSR) during autoexec.bat or config.sys that enable the cards to use VLB 32-bit for hard drive I/O, I have a generic yellow VLB controller I forget who made it in my second (backup) 486 that doesn't even have caching with it, and with a 7200 rpm 10GB drive in there it gets 18-20 MB/s with the drivers loaded. Which, using VLB for hard drives, is the entire reason for using those cards compared to the normal straight-ISA ones.
Reply 8312 of 57981, by easy_john
But DC-300 is an isa16 only scsi controller. They can't work faster, that isa itself.
Reply 8313 of 57981, by kithylin
I went back and saw your photos for the post from a few days ago... they both look like VLB to me? Unless I'm missing something there?
Reply 8314 of 57981, by easy_john
We are talking about this comment Re: Bought these (retro) hardware today
Reply 8315 of 57981, by kithylin
Well.. now I look like an idiot. I thought y'all were discussing the scsi and VLB cards you posted a few days back.. those were the recent tekram stuff on here. I did think it awful weird how a VLB card would work in a K6 system.... I should of googled the part # to see it was ISA before commenting. Oh well.
Reply 8316 of 57981, by Robin4
Bought an Cirrus logic VG1000 with CL GD-520 chip (made by diamond Flower INC), which is the most compatible cga card.. Its going be used in my v-tech laser XT /3 8086 10mhz system..
I really like the card because of the size of the letters.. Which is a same kind v-tech used with their own cards..
Something like this.. I think it is really rare 8-bit version..
Reply 8317 of 57981, by Mut
Every thing only $10 😀
Nothing tested yet, a cap of the creative graphics blaster blown away and need to be repaired.
The lanparty has bad cap and the chipset corners looks bad :'(
Reply 8318 of 57981, by CelGen
Hey wait a minute. I know that machine. In fact, I know who also owns that Sun and half built Beige box behind it.
You live in Vancouver, don't you? 😉
Reply 8319 of 57981, by ODwilly
Nice haul! Honestly I think the chances of that DFI board working are pretty good, I had a 939 Asus board untested for $1 from Goodwill w/o a heatsink or fan knocked around with huge scratches on the pcb knock around in a box for a year before being tested turn out to be 100% functional 😊
