We Don't Go To Ravenholm: Retro Build
First post, by RavenholmDX
Hey Guys,
Been spending a lot of time recently looking into more retro computing, and being in my mid 20's, the 370 era was right before I started building my own computers in the early 2000's. As some of my favourite games are from that era, Half Life, System Shock 2 etc., I decided to put together a gaming rig from that era so I can emulate the experience of the time.
I've spent some time looking into it, and based on suggestions from my lurking here, and the accessibility of some parts to me, I've ordered the following:
  • Intel D815EEA2 Socket 370 ATX Motherboard
  • Kingston ValueRAM 2x256MB 133Mhz SDRAM
I'm also considering ordering the following parts:
  • Intel® Pentium® III Processor - S 1.40 GHz
  • USB Floppy Drive Emulator
What do you think of the above parts (both those I've ordered, and those I plan to)?
What would be your suggestions for the rest of the components? GPU/PSU? Storage? Go with an IDE drive, or SSD/SATA drive?
Thanks for your help!
-Rave
In Progress Build | Intel Pentium III-S 1.4Ghz | Intel D815EEA2 | 512MB PC133 SDRAM | GeForce4 Ti4800SE 128MB | SoundBlaster Live! PCI
Reply 1 of 33, by PhilsComputerLab
Looks good! Can't go wrong with Intel gear IMO.
Reply 2 of 33, by tayyare
Your CPU is what I would choose, and as long as the mobo supports your CPU, it is ok, I think.
For retro gaming, two of the most important parts are video and sound cards. These are the subject of most intense discussions, as far as I can see. My suggestions would be a Geforce2 (GTS, Ultra) or Geforce4 MX or even Geforce4 TI idisplay card (and maybe one or two Voodoo2 boards in addition to that, if you think you need glide support) and an SB AWE64 sound card, but since this is based on personal choice more than anything else, there will be more diverse suggestions, I'm sure.
GA-6VTXE PIII 1.4+512MB
Geforce4 Ti 4200 64MB
Diamond Monster 3D 12MB SLI
SB AWE64 PNP+32MB
Adaptec AHA29160
3com 3C905B-TX
Gotek+CF Reader
Reply 3 of 33, by GeorgeMan
In my similar retro PC final choice, I decided that I wanted at least some nostalgia level. That includes SLOT cpu and ISA sound. The principle was to play most of middle 90s games, till 2000, just before XP kicked-in.
ASUS P2B slot1 mobo, with Intel chipset for stability reasons.
Intel Celeron 1100MHz Tualatin with active slocket (with voltage regulator to provide correct voltage). Why Celeron? To retain the in-spec 100MHz FSB.
256-384MB SDRAM
Geforce 2 GTS
2x VoodooII in SLI
and a SoundBlaster in ISA slot.
If you use no ISA and no Slot, I don't see a reason to choose Pentium III. Just pick a fast Pentium 4 (if you need compatibility with Win 98SE) or an Ivy quadcore i5 for XP.
HP Elitebook 14 G1a | Snapdragon 12core | 32GB LPDDR5X RAM | Adreno GPU | 32" AOC 75Hz 2K IPS + 17" DEC CRT 1024x768 @ 85Hz
Windows 11 on ARM --> pcem ARM | Eden & Dolphin ARM editions
Reply 4 of 33, by RavenholmDX
GeorgeMan wrote:
In my similar retro PC final choice, I decided that I wanted at least some nostalgia level. That includes SLOT cpu and ISA sound […]
256-384MB SDRAM
Geforce 2 GTS
2x VoodooII in SLI
My main PC has a 4670K and GTX 970, so I'm good on the XP-and-up side of things, I just wanted to build, what I would consider, a beastly Windows 98SE PC from that era. Like I mentioned, I don't really have nostalgia for that era in computing, so my needs aren't the same as you, but I appreciate your feedback. Your system sounds good though!
Reply 5 of 33, by RavenholmDX
I've been thinking of getting a few GPUs to play around with, and those sound like solid recommendations! I might pick up a 6800 Ultra and see how that plays in 98SE.
Reply 6 of 33, by GeorgeMan
256-384MB SDRAM
Geforce 2 GTS
2x VoodooII in SLI
A beastly yet officially supported Win 98 build is something I've also done.
A PIII-S is nothing compared to (one of the two) cores of an unlocked E6500K combined with dual channel DDR RAM and Geforce 6800Ultra etc etc. 😁
Win 98, XP & 8.1 fully supported on one dual core PC? Here is my retro approach!
So, you have to specify what you want to do with that PC. 😀
Edit: Link fixed
PS: What motherboard do you have for your 4670K? I think XP support was dropped by Intel when socket 1150 was released. 😉
Reply 7 of 33, by RavenholmDX
GeorgeMan wrote:
A beastly yet officially supported Win 98 build is something I've also done. A PIII-S is nothing compared to (one of the two) co […]
256-384MB SDRAM
Geforce 2 GTS
2x VoodooII in SLI
Edit: Link fixed
I appreciate the feedback, but my main goal here was to build a PC of that 2000/2001 era. It's less about the games, and more about revisiting a socket and CPU architecture that I missed out on. My first real PC was a Pentium 4 when I was about 12 years old, so it's as much as history lesson as it is a gaming platform for me. I will enjoy playing some 98SE classics though. I wasn't aware about the drop in support for XP on Haswell, I'm rocking a Z87MX-D3H motherboard, and looks like it doesn't support XP. I guess I'll need to refurbish that original Pentium 4 rig I still have 😜
Reply 8 of 33, by GeorgeMan
I'm also young enough and my 1st computer was a s478 Celeron, so I know exactly that feeling, to explore older and older computers.
It's called the retro bug, and it won't stop until you obtain a slow 386 or until the money dries out. At least, that's what happened with me. 🤣
So, for your PC of choice, I'd recommend a geforce 4 ti, 384-512MB of ram, a 80GB IDE hdd, and an aureal vortex or soundblaster sound card. Oh, and that Tualatin CPU.
Try to perform all file transfers via 100mbps ethernet, because USB 2.0 PCI cards will get you trouble and USB 1.1 is waaaay too slow.
Setting up an FTP server into your main computer will be a perfect match to support file-wise that old one.
Reply 9 of 33, by tayyare
Just a heads up, I first started my PIII W98SE with an FX6200, then downgraded to FX5200, but both produced problems instead of graphics when it comes to playing some of the games I wanted to play (Windows versions of X-Wing and TIE Fighter, and X-Wing Alliance). Then I further downgraded to Geforce2, now everything is working as they are supposed to be. Thus, the machine in my sig.
A GeForce2 (GTS/Ultra) and very similar GeForce4 MX are more than enough for a PIII system as far as I know, and if they are not pleasing enough, a Geforce4 Ti would be even a better overkill, if a bit more pricey at the same time.
SB AWE64 PNP+32MB
Adaptec AHA29160
3com 3C905B-TX
Gotek+CF Reader
Reply 10 of 33, by PhilsComputerLab
What driver version did you end up using with your GeForce 2, that works well with most games?
Could the FX issues be driver related?
I really want to check out Nvidia for W98 gaming, covered the 3dfx stuff pretty well and want to see what they are like. I will use Slot 1, to avoid AGP issues that plague SS7 boards.
I got quite a few of GF4 MX cards. Also TNT2 and I think one GeForce 3. DVI output would be nice.
Reply 11 of 33, by RavenholmDX
What would be a decent PCI Soundcard that has at least some compatibility with MS-DOS?
Reply 12 of 33, by tayyare
philscomputerlab wrote:
What driver version did you end up using with your GeForce 2, that works well with most games? […]
I don't remember really (I will check and return back to you later", but here are some discussions from the past, which might be helpful a bit:
Comments on a PIII build?
Which nVidia driver (FX5200) for windows 95?
TIE Fighter Collectors CD (W95/98) - Which display card to enable Hardware 3D?
SB AWE64 PNP+32MB
Adaptec AHA29160
3com 3C905B-TX
Gotek+CF Reader
Reply 13 of 33, by PhilsComputerLab
Just read your post on "Comments on a PIII build?". You will enjoy my next project. It will feature quite a few games from your list 😀
Reply 14 of 33, by blank001
An A3D card like the Diamond MX300 is a solid choice for some dos compatibility plus awesome A3D.
After you're done checking out 2001-2002 gaming you should visit what was glorious about 1998-1999 16-bit color with a P3B-F, coppermine, voodoo^3 and A3D 😉
_: K6-III+ 450apz@550, P5A-B, 128Mb CL2, Voodoo 5500 AGP, MX300, AWE64 Gold 32mb, SC-55v2.0
_: Pentium III 1400 S, TUSL2-C, 512Mb CL2, Voodoo 5500 AGP, MX300
Reply 15 of 33, by PhilsComputerLab
+1 for an Aureal Vortex 2 PCI card. Works very well under DOS, and even has a wavetable header.
Reply 16 of 33, by RavenholmDX
I just pulled the trigger on a SB Live CT4760. I looked into the Aureal Vortex2 and it doesn't seem as readily available, or as cheap. I got the SB Live for about 6GBP. Mistake?
Reply 17 of 33, by PhilsComputerLab
Live! is a great card. A lot more common than the Aureal cards. It should get the job done and it has DOS compatibility. I have no personal experience with Live! cards though.
Reply 18 of 33, by tayyare
No, definitely not. Live Is a good card (most versions anyway, definitely including 4760) and would be also my choice for a PIII based pure Windows 98 setup.
One question is still there: Do you want to play dos games? If the answer is yes, I would definitely suggest AWE64. You will give up EAX, but for the price of much better DOS compatibility, infinitely less hassle, more than very acceptable sound quality (well, IMHO).
EDIT: Forget about AWE64, I just realized that your choice of motherboard does not have any ISA slots. 🤣
SB AWE64 PNP+32MB
Adaptec AHA29160
3com 3C905B-TX
Gotek+CF Reader
Reply 19 of 33, by Darkman
Im using the same motherboard in my PIII build, and its a great motherboard, not too many options as far as tweaking, but rock solid.
and the Live is a very nice card. though the Windows2000 drivers could have been better. still better than the Aureals which had very limited Win2K support (although if youre going with Win2K an Audigy is probably better)
