Reply 8380 of 60053, by kithylin
philscomputerlab wrote:
kithylin wrote:
Please show me your dual power supply adapter thing... I'm interested a lot in that.
When I looked for it, I expected something really complicated, mini nuclear reactor style. But turns out it's just a little gadget 🤣
Here is a eBay article link: http://www.ebay.com/itm/24-Pin-Main-Second-Du … =item43c8165319
OH! That... yeah. That thing it's self doesn't actually distribute load. It just makes the second one switch on when the main one does / at the same time. Runs the ATX-POWER-ON signal off to a second atx plug that plugs in to the second one. Useful still. Thanks! I might actually need this as I'm considering some plans for my i7 in the near future to require 1000-watt + 750 watt double units, and found a double-psu case for it.
Reply 8381 of 60053, by PhilsComputerLab
Well, isn't that what you want?
Drive the motherboard with one PSU, and the graphics card, hard drive and optical with the other one. And there you have your load distributed.
Reply 8382 of 60053, by Lukeno94
Why would you need 1.75 kW of power for any i7-based system? If you've got that much power to burn, I'd be going with one of the Xeons with 14 to 18 cores.
Reply 8383 of 60053, by easy_john
When I've read about "Dual PSU adapter. Allows using two Power supplies to spread the load" at first place, I've thinking about module, that can drive modern mobo from two cheap psu. Or able to hotswap psu in cheap home server. :) Unfortunately this is not so easy, as just connector to simultaneously power two psu from one mobo.
Pentium2 450/256mb/4gb/ati rage 128+voodoo2/SB awe32 8mb+db50xg/GUS PnP 8mb/TB Tropez 2mb
486 DX2-66/32mb/8gb/tseng4000 2mb/SB 16+WB/GUS 1mb/LAPC-I
286 12mhz/4mb/512mb/Vga 1mb/SB 2.0+Covox
PegasosII G4 / Amiga 4000 / Amiga1200 / Amiga 600
Reply 8384 of 60053, by PhilsComputerLab
Who said it's for an i7? 🤣
Reply 8385 of 60053, by Lukeno94
kithylin did.
Also, easy_john, I hope by "cheap" you're not referring to those junk $20 or so units, with no certification, no regulation and that can't produced anywhere near the kind of power they claim to be able to do.
Reply 8386 of 60053, by PhilsComputerLab
Ah, yes, I see it now.
Reply 8387 of 60053, by kithylin
Those new ones with those cores are multiplier locked, can't overclock, and thus no good for gaming.
And I'm not intending to actually use all 1.75 KW, power supplies are most optimal on efficiency when they're in the center of their load. I was thinking, some day, something like 3 x gtx-770's in a system and try to bring back some of the 15,000 rpm sas drives I used to have back in to here. Even with all of that I was estimating total actual at-outlet draw only around 1KW - 1.2KW, and that presents a choice. Buy a $400+ 1.4KW - 1.5KW power supply to handle it all in one, or use two cheaper ones and use that for less than half the price. (which I already own the 1KW one, and just yesterday got the 750 working for free).
Besides that, with big platter drives it's more for providing amperage than it is actual power-draw-at-outlet, it's weird to explain. Like my NAS server requires a 750 watt power supply for it's hard drives, but only actually pulls 95-115 watts @ outlet on the input side.
Just because we have big wattage power supplies, it's not always that we're actually going to pull that much power, I'm learning some systems need bigger ones even if the power pull @ outlet is low.
Reply 8388 of 60053, by Formulator
Roland SC-55, under the Focusrite. Never had one before.
The attachment IMG_0197.JPG is no longer available
Reply 8389 of 60053, by TeddyTheBear
This seems like one of those statements that are way too general that no one should believe at face value. Just looking on google for atx power supply efficiency graphs shows that most of them only have 3 data points at 20%, either 50% or some other peak, and 100% load. Only 3 data points are bound to make some kind of artificial peak so that could be where this statement comes from but that's just speculation on my part. Other graphs with more data points usually show a much larger flatter range of load with good efficiency but every powersupply is going to be different and if you need to know how yours performs then you need to test it yourself.
Reply 8390 of 60053, by keropi
an excellent choice my good Sir, enjoy! 😎
🎵 🎧 ⏳ ⚡ SoundVision PRO,MK1869 , PCMIDI MPU , OrpheusII , Megacard and 🎶GoldLib soundcard website
Reply 8391 of 60053, by Lukeno94
The reason for those points is simple; that's what the 80+ standards are based on. 😀
Reply 8392 of 60053, by Skyscraper
I bought these random CPUs for ~6 euro.
Im hoping for a PIII 866(133) or 650(100) and a 533(133) as I lack Coppermine CPUs with 6.5 and 4 multiplier which creates holes in my P6 scaling project.
Reply 8393 of 60053, by havli
I wish CPUs were so cheap here... 😒
Anyway, some new stuff:
Radeon X1900 XTX
Radeon HD 2900 XT
Intel S5000PSL - dual socket 771 board supporting all CPUs starting with netburst all the way up to 45nm quad-core Xeon (FSB 1333). At the moment I'm testing it using single Xeon L5410 (4x 2,33 GHz, 12MB L2) and 8GB DDR2 FB-DIMM (quad channel) 😈 Working perfectly and very power efficient compared to Socket F K8 Opterons.
Reply 8394 of 60053, by Skyscraper
havli wrote:
I wish CPUs were so cheap here... :blah: […]
Radeon X1900 XTX
Radeon HD 2900 XT
Awesome stuff.
If you get two X5470 that board will last you a long time performance wise. They are still somewhat expensive though because of the S775/S771 mod.
Reply 8395 of 60053, by havli
I'll start with two Xeon 5080 - the ultimate NetBurst king. And later some quads as well, but I prefer more cost effective models. Maybe even older 65nm Xeons - X5355 is for sale at local auction, very good price at the moment.
Reply 8396 of 60053, by PhilsComputerLab
Work asked me to recycle some old computers 🤣
This will be ongoing / slow process, so I Can my time, test it all, chuck the non-working gear and hoard the good stuff 😀
Intel G41 chipset board with E4500 CPU and two 1 GB sticks of DDR2 (removed). Also got a SATA optical drives. HDD I still need to sort out a process (wiping) that keeps the brass happy.
35A on the 5V and also -5V old school PSU:
QdUha01h.jpg?1
Reply 8397 of 60053, by PcBytes
35A on the 5V and also -5V old school PSU: […]
QdUha01h.jpg?1
I assume the MPT-4012 is a 12v design and the one under it is a 5v design?
Reply 8398 of 60053, by PhilsComputerLab
Yes, very likely. Tried with my Athlon XP 3200+ machine, and the voltage readings are much improved. Around 4.7 - 4.8 under full load.
Reply 8399 of 60053, by tayyare
What I don't understand is, why color coding is different while both are ATX power supplies (although apparently different ATX revisions).
+12V : Yellow vs. Yellow/Black
P.G. : Gray vs. Orange
P.S. on : Green vs. Gray
5V sb : Purple vs. Orange
Messed up sticker?
GA-6VTXE PIII 1.4+512MB
Geforce4 Ti 4200 64MB
Diamond Monster 3D 12MB SLI
SB AWE64 PNP+32MB
Adaptec AHA29160
3com 3C905B-TX
Gotek+CF Reader
