We Don't Go To Ravenholm: Retro Build
Reply 20 of 33, by tayyare
philscomputerlab wrote:
Just read your post on "Comments on a PIII build?". You will enjoy my next project. It will feature quite a few games from your list 😀
That's cool!..🤣
GA-6VTXE PIII 1.4+512MB
Geforce4 Ti 4200 64MB
Diamond Monster 3D 12MB SLI
SB AWE64 PNP+32MB
Adaptec AHA29160
3com 3C905B-TX
Gotek+CF Reader
Reply 21 of 33, by RavenholmDX
tayyare wrote:
No, definitely not. Live Is a good card (most versions anyway, definitely including 4760) and would be also my choice for a PIII […]
+1 for an Aureal Vortex 2 PCI card. Works very well under DOS, and even has a wavetable header.
I just pulled the trigger on a SB Live CT4760. I looked into the Aureal Vortex2 and it doesn't seem as readily available, or as cheap. I got the SB Live for about 6GBP. Mistake?
No, definitely not. Live Is a good card (most versions anyway, definitely including 4760) and would be also my choice for a PIII based pure Windows 98 setup.
One question is still there: Do you want to play dos games? If the answer is yes, I would definitely suggest AWE64. You will give up EAX, but for the price of much better DOS compatibility, infinitely less hassle, more than very acceptable sound quality (well, IMHO).
EDIT: Forget about AWE64, I just realized that your choice of motherboard does not have any ISA slots. 🤣
Thanks for the feedback! Once this build is finished and the honeymoon period wears off, I'm going to start looking at a DOS build!
In Progress Build | Intel Pentium III-S 1.4Ghz | Intel D815EEA2 | 512MB PC133 SDRAM | GeForce4 Ti4800SE 128MB | SoundBlaster Live! PCI
Reply 22 of 33, by blank001
I will maintain that until much later (audigy 2 era) EAX was hardly a thing to give up! Now A3d, that's something else.
_: K6-III+ 450apz@550, P5A-B, 128Mb CL2, Voodoo 5500 AGP, MX300, AWE64 Gold 32mb, SC-55v2.0
_: Pentium III 1400 S, TUSL2-C, 512Mb CL2, Voodoo 5500 AGP, MX300
Reply 23 of 33, by GeorgeMan
Oh, the bug was begun to bite deeper and deeper I see! 🤣
HP Elitebook 14 G1a | Snapdragon 12core | 32GB LPDDR5X RAM | Adreno GPU | 32" AOC 75Hz 2K IPS + 17" DEC CRT 1024x768 @ 85Hz
Windows 11 on ARM --> pcem ARM | Eden & Dolphin ARM editions
Reply 24 of 33, by RavenholmDX
The real question is, how do I get my missus to not throw a fit when all these new towers start crawling out of the woodwork 😜
EDIT: I just got a DEAL on a Ti4800SE. Sometimes it pays to search on eBay using the model number, and not the actual model name. It's the Asus v9480/TVD (I'm not sure what the TVD designation is for, possibly S-Video/TV output?)
Reply 25 of 33, by RavenholmDX
First (of many) parts arrived yesterday. Took them on a little 'photoshoot'.
Original uncompressed images (plus more) here.
Reply 26 of 33, by boxpressed
Not sure if the Ti4800SE is faster than the Ti4600, but either should be more than enough. I've been comparing my Ti4600 to my Quadro 2 Pro (performance somewhere between GF 2 Ti and GF 2 Ultra), and the two turn in almost identical performance on Unreal Gold on 700MHz, 1000MHz, and 1300MHz P3s/Celerons. The Ti4600 is a lot faster with OpenGL, however.
Reply 27 of 33, by PhilsComputerLab
AFAIK the 4800SE is the 4400 with AGP 8x interface. There is a true 4800, which also goes under the name of 4600 AGP 8x. That is the 4600 with AGP 8x interface. That card is quite rate I believe.
Reply 28 of 33, by RavenholmDX
Yeah, I picked up the Ti4800SE at a good price, was cheaper than any Ti4200 at the time, let alone Ti4400.
I've ordered a couple of cards since:
ATI Rage128 Pro AGP
MSI Riva TNT2 Pro AGP
Good choices?
Reply 29 of 33, by blank001
That's quite a photo shoot. Nice!
Reply 30 of 33, by tayyare
I recently (a few months ago?) purchased one from ebay, (actually won the auction as mine was the only bid: 25 USD). It is an Asus V8460 Ultra Deluxe (4600 ultra 4x), with all the package contents like breakout cables and 3D(?) glasses. I'm still amazed by the weight of the card. It is as heavy as my much modern "extra-big-double-slot-huge-heat-spreader-double-fan" cards. It has so much copper on it! 😁
http://www.techpowerup.com/gpudb/b1868/asus-v … tra-deluxe.html
SB AWE64 PNP+32MB
Adaptec AHA29160
3com 3C905B-TX
Gotek+CF Reader
Reply 31 of 33, by tayyare
RavenholmDX wrote:
First (of many) parts arrived yesterday. Took them on a little 'photoshoot'. […]
I really don't know how you did it but, in this picture, the mobo looks like a miniaturized mascot or something, not like a real board. 😁
SB AWE64 PNP+32MB
Adaptec AHA29160
3com 3C905B-TX
Gotek+CF Reader
Reply 32 of 33, by blank001
He's using a rather long lens here, hence the compressed perspective. Maybe something like 85mm for a 35mm camera.
Reply 33 of 33, by RavenholmDX
Was taken at around 130mm if I remember correctly. But yeah, it's a telephoto lens, gives really good bokeh for shots like this 😀
