First post, by sel666
								sel666
								Offline
			anyone manages to get the cd version of return to zork properly? earlier versions of dosbox made it possible to install, but then the beginning was so slow that you couldnt even do anything. this new dosbox versions does not even run the install program, but if i install some other way the slowdowns are still the same. the floppy version rounds ok for some reason.
