Mix Midi with Digital Sound
Reply 40 of 42, by PhilsComputerLab
Did you really watch my 4 in 1 video? 😊
386 mode:
FSB 66 MHz
Multiplier 2x
SoftMPU can be downloaded from here: http://bjt42.github.io/softmpu/
Reply 41 of 42, by NooNaN
I guess I just thought you had to use a multiplier that divided .5 into the chip speed....whoops.
Tried SoftMPU...Xeen works now! Laura Bow 1 now does send data to the MT-32, but then the MT-32 light just keeps flashing and it hangs still.
I'll mess with the jumpers and get the FSB down as well. Will let you know. Thanks again so much!!
Reply 42 of 42, by PhilsComputerLab
SoftMPU has one downside, it can take a long time for data to be submitted to the MT-32. So with Laura Bow, make sure you do wait long enough, even if it appears that it's stuck.
