Reply 8760 of 53287, by PeterLI
Last week I bought 2 CT2740s for very cheap. They arrived today and both work 100%. Good alternative to CT1740/CT2230. Especially because they have a volume dial in the rear.
Reply 8761 of 53287, by dogchainx
Finally tested a 486 motherboard with most likely fake cache on it (It sais WRITE BACK on the chips, and they are soldered to he motherboard). I may have made a mistake with trying to change cache settings in the bios, because i think I killed the board by changing BIOS cache settings....very odd.
I booted it up, went into the bios (Phoenix GUI one) and changed cache from Write-through to Write-back.....system immediately froze and won't boot. I cleared CMOS, and tried to boot....NOTHING. no post codes on the ISA diagnostic cards. I'm not sure how I could have killed the board with that one setting. I might try an extended BIOS clear, but I really do think that changing the bios settings killed the board. I pulled the battery, and will try booting tomorrow morning.
386DX-40MHz-8MB-540MB+428MB+Speedstar64@2MB+SoundBlaster Pro+MT-32/MKII
486DX2-66Mhz-16MB-4.3GB+SpeedStar64 VLB DRAM 2MB+AWE32/SB16+SCB-55
MY BLOG RETRO PC BLOG: https://bitbyted.wordpress.com/
Reply 8762 of 53287, by 133MHz
I have a 486 board that takes days to fully clear its CMOS memory without a battery, so it could be possible.
http://133FSB.wordpress.com
Reply 8763 of 53287, by keropi
I don't see an OPL chip on them, or OPL logo - did a google image search ... do your cards have anything OPL related?
Reply 8764 of 53287, by tokroger
One nice old VGA-adaptor. This was used in IBM 5160 but it was far gone already. I took the case in the attic and this Trident TVGA8800BR-based card. Don't know if this works but it's nice piece of history none the less 😀
Reply 8765 of 53287, by Artex
Nabbed these green-topped beauties for $60 through a local eBay auction. Pins = OK!
Reply 8766 of 53287, by dogchainx
Artex wrote:
Nabbed these green-topped beauties for $60 through a local eBay auction. Pins = OK! […]
I saw that auction..... 😎
I was mostly interested in the 386to486. If i didn't already have one, I would have bid on it as well. Glad to know a Vogon got it!
Reply 8767 of 53287, by dogchainx
I fiddled with it this morning. I just think the board is damaged, or the CMOS is as well......I have to SHORT the "reset" pins while clearing CMOS. This works 1 out of 6 tries to boot the system. Also, I can't boot with an ISA card in it...i HAVE to use a VLB card to get to the BIOS screen. Very odd. SInce I bought this board mainly for the RAM, CPU overdrive, and the cooler (It was $15), I don't care much that this board has problems. Interesting seeing the FAKE CACHE chips anyways.
Reply 8768 of 53287, by Sutekh94
I'm pretty certain that the CT2740 uses the CT1747 chip, much like the CT2290 and CT2230, which has a Yamaha OPL FM synth core in it.
My YouTube | My DeviantArt
Reply 8769 of 53287, by Robin4
keropi wrote:
Robin4 wrote:
keropi wrote:
that's a 360kb 5.25" floppy controller right?
I think it would do 720KB also... This is one of the later first controllers. But it doesnt have the logic onboard to do 1.2MB and 1.44 High capacity.
really? worths a shot then to try , I happen to have a 720kb 3.5" FDD 🤣
thanks for the info
I know almost for sure, because iam from the 80s.. I remembered it that it also can do 720KB. Only the really first controllers could do 360KB only..
That controller you have there is one of the later low density controllers. But i think it could also work with an 1.44 MB floppy drive in 720KB mode only.
Reply 8770 of 53287, by PeterLI
Bought a boxed AWE32 today. Really cheap. Will be at my parents house in NL next month hopefully. I will probably keep it to trade.
Reply 8771 of 53287, by brostenen
Is that a 2760, and is that tape holding the modules in place?
Nice find though. And boxed. Just great to have as it is "complete" this way.
If it's a 2760, then it's one of the better 32's, and it can bring in some good value.
Reply 8772 of 53287, by PeterLI
Indeed. I will be looking to get some CT1600/10/20/80/90/2600s for it. 🤣
Reply 8773 of 53287, by oerk
Skyscraper wrote:
That sounds great :) […]
oerk wrote:
If you don't mind shipping to Germany and back, I could solder leads to your SIMMs... free of charge of course.
That sounds great 😀
Soldering on simms are beyond my ability as my hands isnt steady enough, I would just create shorts everywhere.
First I need to see that the board is fully functional and read up on what kind of 30pin 1MB modules it likes best.
If you're willing to take me up on that offer, PM me.
Reply 8775 of 53287, by Tuxality
Small gift from my girlfriend. 😊 Quite interesting card, it's a shame that it doesn't have fully featured OpenGL ICD. It comes with 8MB VRAM although dxdiag says that it does have approx. 9,5MB VRAM. It's funny that using the slider in Direct3D tab to the "performance" level makes this card to render Matrox Mystique quality graphics or just shitty for short. 😁 To be honest this card is quite better than I expected. Does anybody know if this card originally came only with this weird heatsink? I would love to play more with this card, but it can get too hot even in normal operation...
Reply 8776 of 53287, by kithylin
I once at one point in time owned a STB Systems PCI card that looked quite similar to yours. It had the exact same heatsink design on it's chip, and it got rather hot too. I think that's a 'standard' heatsink for STB Systems video cards in the late `90's.
Reply 8777 of 53287, by brassicGamer
I bought one of these new in 1995. No longer have it 😐
But today I bought this! I found this in a local paper for a tenner and am collecting in Wednesday. Can't wait to see what's inside. I've read that some Packard Bells had 3DFX hardware built in, is that right? Then again it's just as likely to be a heap of crap but look! It's boxed, it's got a remote control and is apparently running Windows 95 😊
Reply 8778 of 53287, by HighTreason
3DFX built in!? And I thought PB couldn't sink any lower. 😜 😉
Hope it works well for you man. We used to have a machine like that where I worked, it was actually pretty decent so far as common Pentium boxes went - at least, it ran Excel 97 and didn't break down. I also used to have that same monitor but some dickhead stole it.
Reply 8779 of 53287, by Sutekh94
Yup: http://www.thedodgegarage.com/3dfx/v3.htm
It'll be towards the bottom of the page, but yes, there does exist Packard Bells with a V3 bolted on to the motherboard.
