First post, by dosfriend
- Newbie
Recently I built a Win98 / DOS machine, based on Asus P3B-F (dual ISA) and a PIII.
The idea was to run many Win98 and DOS games on it, so for a good compatibility I put the AWE64 and the GUS PNP together.
Followed Phil's guide to DOS mode, which gave me AWE64 detected correctly after installing his driver pack.
As soon as I plug the GUS PNP, CTCM complains at boot showing up this error messages:
ERROR: Bad Resource Data Checksum (Vendor ID 0) Expected=f8 Actual=0
ERROR: Bad Resource Data Checksum (Vendor ID 100561e) Expected=f8 Actual=0
This makes AWE64 FM synth silent (tested with DOOM). If the GUS PNP is not plugged into the motherboard, there is no error message and FM works fine.
GUS DOS drivers aren't installed, only Windows drivers. This GUS works without any issue on Windows.
Is it possible to have both cards running on the system?
Any help is appreciated
