First post, by lolo799
After the regular DV-7, here is the upgraded model DV-7DL, still running under BeOS 5 Pro.
Specs:
Motherboard DFI GIC68-D
http://www.motherboards.org/mobot/motherboard … _d/DFI/GIC68-D/
chipset 815E
Celeron 1200MHz
256MB PC100
Intel Integrated Graphics with an AGP 2x/4x port, compatible with a GPA card (Graphics Performance Accelerator card with 4MB display cache.)
AC97 audio
RealTek 8100 LAN
As you can see there, it has a slim dvd-rom drive with an adapter, weird idea not to go with a regular 5.25" drive...
The RJ45, parallel, joystick, serial and audio connectors are hidden behind the plate.
Some screenshots of the installed software:
